Hammered Paint on Steel Wheels? - JeepForum.com
post #1 of 7 Old 01-18-2007, 07:08 PM Thread Starter
Woodyhfd
Has anybody used Hammered paint on steel wheels?
I've used it on a bunch of stuff and I love it. I've had the best results on sandblasted metal WITHOUT primer (it doesn't "fisheye" properly for the hammered look if you blast and prime).
Anyway, I was wondering if it's tough enough to use on wheels or if I should just use that special wheel paint.
I have some crappy old steelies and I scored some good used Blizzaks. I want to blast and paint them. I'd like to keep my alloys out of the salt this winter.
Unless, of course, someone near Connecticut has a set of nice stock steel wheels that they'd like to sell me cheap....
"There's only two things in life, but I forget what they are." -John Hiatt
Woodyhfd is offline
post #2 of 7 Old 01-18-2007, 07:29 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
better question is will that paint hold up to heat from brakes?
RnEmOvr is offline
post #3 of 7 Old 01-18-2007, 07:46 PM
BERLINA_BLACK
BERLINA_BLACK's Avatar
I've used that paint lots of times on projects and it works great for covering blemishes, etc. However the hammered-style paint of today is only sprayed on and that's it. Back in the 50's and 60's & even earlier when it was used professionally, the painting process included a "baking" method which made it really durable.
My experience with the spray cans is that it chips and scratches easily. I dunno about the heat factor with the wheels or how it would hold up in the weather.
It does look nice and the key when spraying the hammered paint... less is more... the heavier you spray it on the LESS the paint will have a hammered look.
00 JEEP TJ SPORT
06 HONDA S2000
BERLINA_BLACK is offline
post #4 of 7 Old 01-19-2007, 08:04 AM Thread Starter
Woodyhfd
That's the main reason that I asked in the first place.
Woodyhfd is offline
post #5 of 7 Old 01-19-2007, 10:39 AM
BlueFlame
BlueFlame's Avatar
Never paint hammered...
Should be fine, especially for what you want it for.
You might try to paint around the bead area with gloss though.
Since its winter time, you might stick them in your oven one at a time to fully cure the paint. If you do this, do NOT overdo it. Lowest heat (say 150) for a half hour will do wonders for durability. If you can't set your oven that low, heat it up, turn it off, when it's at 150 toss the wheel in there, and leave it for a half hour. Repeat for each wheel.
Oh - and it will stink up the house and get you in trouble unless you're a bachelor - be warned!
An alternative is a heat lamp, out in the garage....
Heat from brakes should not be an issue, the wheels themselves don't take on much heat. Your hood gets hotter from sitting in the sun on a summer day than your wheels get after a good hard braking. Plus, it's usually cold out when you run blizzaks.
BlueFlame is offline
post #6 of 7 Old 01-19-2007, 03:35 PM Thread Starter
Woodyhfd
If I decide to start messing with the oven, I'll just powder coat them. I've got a spare oven but it's not hooked up, and I'd need to buy a lot more powder.
Woodyhfd is offline
post #7 of 7 Old 01-20-2007, 07:47 AM
gunthagunth
gunthagunth's Avatar
I painted a set of wheels with that paint. I used like 4 coats and once coat of the recommended primer. They came out looking good. Not sure how they held up to abuse because I sold them just afterwards. But its nice to just run a touchup with a spraybomb. Jolleyroger on here ended up buying them off me. Maybe you could shoot him a pm and ask how they're holding up?
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
1996 XJ Steel Wheels Paint Sirus789 Tires & Wheels 7 10-23-2009 12:48 PM
paint stainless steel xltj General Jeep & Off-Road Equipment 4 02-08-2008 11:04 AM
paint/hammered claytonandson General Jeep & Off-Road Equipment 5 08-16-2007 08:49 AM
What paint is best for repainting steel wheels 18to80DDC Tires & Wheels 5 10-16-2005 08:00 AM
Pics of Hammerite Hammered or Smooth Black Paint? Stricken Fabrication Shop 5 02-20-2004 03:01 PM
