Had to replace a tire... - JeepForum.com
post #1 of 1 Old 07-29-2012, 10:19 PM Thread Starter
SDscubadiver
A couple of weeks ago I was off roading with my 2011 4X4 Grand Cherokee and experienced a blow out of my front left tire. The vehicle has 18"stock Michelin Latitude Tour with around 20K miles on them.
Unfortunately, in the remote area of Utah we were in I could not get a replacement Michelin and ended up having to get a Dunlap A/T Radial Rover 18" replacement. Had the repair shop put the new tire on the rear and moved the rear Michelin tire to the front.
Is there going to be a problem if I continue to drive the vehicle with the new Dunlap? Someone told me you could not mix tires and suggested I replace the remaining tires to match them up. There is still plenty of good tred on the Michelin's and I would prefer to hold off if I can. Is replacing necessary? Is there a possibility I can cause damage to the differential leaving it as is?
Thanks for your thoughts on this.
SDscubadiver is offline
Tire pressure in Baja Claws and Lug Bolt Replace? Magus2727 Tires & Wheels 1 07-03-2009 04:48 AM
Need to replace spare tire?? BigJeff Tires & Wheels 2 03-06-2009 11:37 AM
Should tire shop replace this tire? linexrandy Tires & Wheels 9 11-27-2008 06:31 PM
not sure how to word this question (Metric tire size equivalent for 31" tall tire?) fphipps Tires & Wheels 4 11-16-2008 08:33 PM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
