Quantcast Got my tires rotated. Now tires are excessively loud at highway speeds. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Got my tires rotated. Now tires are excessively loud at highway speeds.
Brand new! XJ Rear DIY Bumper from JcrOffroad!Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 07-22-2007, 12:45 AM   #1
televisionary
Is this normal?
televisionary is offline   Reply With Quote
Old 07-22-2007, 12:48 AM   #2
Crashnburn80
MTRs do tend to get louder as they wear...
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 07-22-2007, 12:49 AM   #3
televisionary
Ah. Thanks for the quick reply.
Old 07-22-2007, 12:56 AM   #4
KaiserJeep
You need to rotate every 3000 miles to avoid this.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline   Reply With Quote
Old 07-22-2007, 08:27 AM   #5
RLD831
Give it about 200-300 miles and it'll quiet down.
Black 2001 Wrangler SE, stats in profile
RLD831 is offline   Reply With Quote
Old 07-22-2007, 08:35 AM   #6
Slithering_Joe
X2
When I bought my Jeep I complained about the tires. They were really loud. The guy aggreed to install new tires or knock off $400 from the price. I opted for the discount since I knew the tires would quiet down after some use. Within 500 miles everything quieted down.
4.0L TJ 5.7L CTS 3.7L KJ
Slithering_Joe is offline   Reply With Quote
Old 07-22-2007, 09:02 AM   #7
spyder6
Just violated my Parole
spyder6's Avatar
my MT/R's were REALLY loud in the begining, then after about 300 miles they quieted down a little, but were still REALLY loud. then i put BFG muds (315x75x16r) on and they're more quiet than 9.5" wide MT/R's
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 07-22-2007, 09:13 AM   #8
yellajeep04
I experianced this recently also, the driverside rear tire sounded like a wwii airplane at full throttle. The tire's tread was sloped to one side! I found my front-end alighnment was WAYYYY off center. I gotta pay more attention to that on a regular basis. The sloped tire is now my spare. I didn't have the patience to wait for it to wear down.
Mud is for fun, rocks are for throwing.
yellajeep04 is offline   Reply With Quote
Old 07-22-2007, 09:26 AM   #9
Postal
They should be a little bit louder. It also depends on how they were rotated. I had one place that did mine, and they were not as loud as they typically are when I have them done.
I looked and found that they had just moved the front to the rear buy didn't swap left to right. I swapped the RR with the RL and they were much louder simply because the tread is not cutting in the direction opposite of the previous 5k miles.
Your rotation should be FR to RL and FL to RR and throw the spare into the mix as well.
I haven't rotated my spare in because I knew I was going to move from 33s to 35s and the shop said they would credit me toward the 33 if it still have the little porcipine things on the tread.
Suspension/Axle: 2"BL/2"SL:4.88 gears:D30/D44
Wheel/Tire: 15x8 American Racing Mojaves :35x12.5 BFGs
Armor: Rockcrusher bumpers and rocker guards
Int: Husky liners & Neoprene Front & Rear
Recovery: Warn 9000ti
Next: Discos : D-rings F/R: Audio : CB : Offroad lighting
Postal is offline   Reply With Quote
Old 06-06-2010, 08:05 PM   #10
swannee
loud tires
Rotate every 3k or at oil change, pressure is critical run what's on the tire....
Pull my JK behind motor home you can't change oil in an RV Park. Have to use jiffy lube and wal-mart both have bleed air from 50# to 35# whats on the door for OEM tires. Pulled Jeep across Texas to Utah very loud.. have been trying to wear them round again lost alot of tire but not as loud..
swannee is offline   Reply With Quote
Old 06-07-2010, 04:52 PM   #11
BlueFlame
Originally Posted by swannee View Post
Rotate every 3k or at oil change, pressure is critical run what's on the tire......
Um, no. What's on the tire is the max pressure, which will be Way too high for a TJ.
BlueFlame is offline   Reply With Quote
Old 06-07-2010, 05:07 PM   #12
Mooseknuckles
No joke... just because my tires can hold 50psi safely doesn't mean they're gonna hold it happily.
The Green Machine 2005 Wrangler Sport, 31" Michelin LTX A/T's on 15x8 Cragar V5's
The Build Thread: http://www.jeepforum.com/forum/f22/green-machine-1015950/
HAYTHANKS to Rammer500 for the Membership Upgrade!
Mooseknuckles is offline   Reply With Quote
Old 06-08-2010, 10:18 AM   #13
samger2
All these answers depend on how bad your tires are cupped...if they've been on the rear for a long time and are cupped severely, no amount of driving will quiet them down...if they are just slightly cupped then they can probably wear down a bit and be ok. Snap some close up pics of your front tires...lets see how cupped they are.
samger2 is offline   Reply With Quote
Old 06-08-2010, 02:29 PM   #14
Imped
TITS
Imped's Avatar
You're obviously a genius. Crappy advice and you bring up a 3 year old thread.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 06-08-2010, 08:15 PM   #15
swannee
What crappy information? How do you take care of your tires?
Glock Forum
