goodyear wrangler duratrac - Page 79 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > goodyear wrangler duratrac
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 09-30-2010, 06:32 PM   #1171
CB3
Originally Posted by shadowulf View Post
Done, I put in a request for (Duratrac) 33x10.50R15s too
If enough of us do that, they will listen. The reason they haven't already done it is that they assume there is no demand for it.
If they find out there is a demand for it, then they'll start making it.
See post 1169.
CB3 is offline   Reply With Quote
Unread 10-01-2010, 05:33 AM   #1172
sinjans
2010 JK Wrangler
Why don't those interested post the goodyear link to their signature for that extra attention? Just a suggestion
sinjans is offline   Reply With Quote
Unread 10-01-2010, 10:04 PM   #1173
Fargo
Done, I put in a request for 33x10.50R15s too
Sorry guys, I think a 33" tire is too much sidewall on a 15" rim. I asked for a 255/85/16 or a 33x10.5R17. Personally I'm surprised no one makes a 33x10.5R17. It seems like a perfect size for many applications. It would be an easy upgrade for JK owners, FJ cruisers, Tacomas and a lot of other trucks that come stock with a 265/75/16 or 17".
6spd manual
LJ Owners Group member #110
Fargo is offline   Reply With Quote
Unread 10-01-2010, 10:20 PM   #1174
shadowulf
Then the 34x9.50 that Interco has must really suck
BFG has made the 33" size for many years in the AT/MT/Baja styles, even in a 33x9.50R15. And if they have to add a ply to the sidewall to strengthen it, so be it.
I'm kinda old school in the fact that I want more tire for traction and conforming to obstacles, and less wheel to get bent or broken.
I know that doesn't fit today's thinking. But then I remember when if you wanted a "Big Tire", you had to run 16.5" wheels and adapters.
Viva la "choice"
shadowulf is offline   Reply With Quote
Unread 10-02-2010, 06:41 AM   #1175
bluetdi1
2004 JK Wrangler
DD Recommended Size
I hate doing this, but here goes. I did search and search and the more I searched, the more confused I became. What size, etc.
I have a bone stock 07 Rubicon with the OEM standard tires and wheels (17). I need to replace the tires. I have been off road once since I got the car (March '10). This Rubicon is my DD and I love the car. My chief requirement is sound! I want a quieter tire. The original tires are 32" or so and I would like to replace the tires with 33's or as close as possible. I have read that there will be some rubbing at full turns.
Can someone recommend a replacement size. I have been at Tire Rack and there are a sizes, sizes and sizes. I am clueless.
Can someone who has a rubi, recommend a Goodyear Duratrac tire in a slightly taller tire (33's) size?
Thanks
Russ
bluetdi1 is offline   Reply With Quote
Unread 10-02-2010, 10:06 AM   #1176
GregB_00XJ
GregB_00XJ's Avatar
I have a bone stock 07 Rubicon with the OEM standard tires and wheels (17). I need to replace the tires. I have been off road once since I got the JEEP (March '10). This Rubicon is my DD and I love the JEEP. My chief requirement is sound! I want a quieter tire. The original tires are 32" or so and I would like to replace the tires with 33's or as close as possible. I have read that there will be some rubbing at full turns.
Thanks
Russ
Looks like they only have a 32 or a 34. As others have mentioned, there is no 33 for a 17" rim. If there is enough demand they would likely make them, but that would need to be a lot of requests.
Oh and FYP...
Maybe you need to go to a 34? Doubt it will fit stock, but I really have no idea.
2000 Jeep Cherokee Classic XJ in COTM Contest!! - 2005 Jeep Grand Cherokee LTD 5.7L WK
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Unread 10-02-2010, 04:23 PM   #1177
consfearacy
285/70R17 is listed at 32.8 (about typical for a 33")
consfearacy is offline   Reply With Quote
Unread 10-02-2010, 07:09 PM   #1178
GregB_00XJ
GregB_00XJ's Avatar
Good call.
____=__=
l l ,[_____],
()_) ()_)--o-)_)
Unread 10-07-2010, 12:02 AM   #1179
lizardking31
Duratrac E's 245/75/16E
Got E range on my stock LJ.
Very stiff/rough at 45psi from the shop.
Dropped them to 34psi and liking them there.
245/75/16E is Rubicon stock from the factory for my model/year.
Not really sure if it's because of the hard top or not.
Come to think of it. I haven't had the hard top on yet since I
got the Duras.
05 LJ Rubicon, stock
lizardking31 is offline   Reply With Quote
Unread 10-08-2010, 03:23 AM   #1180
Elitejeeper
Just got a set of duratracs 33x12.50x15 today. I must say these are absolutely awesome. Very quiet, got rid of an annoying rattle I had with my old mud tires. Buy these tires if you're considering them.
And they look awesome.
Elitejeeper is offline   Reply With Quote
Unread 11-05-2010, 08:33 PM   #1181
Jblankster
quick update, some stuff was previously stated
got my tires half way though last winter, about 3 months ago the 2 fronts were acting funny (shook when turning). took em back in wheel weights were still on, re balanced=couldnt be balanced. determined they had a defect somehow so i got 2 new fronts FOR FREE. problem gone since
overall tires starting to wear more (normal wear, i mean ive just had em for a while) and i THINK im starting to hear them more. i dont know if i just got used to it compared to the MTR's or what but i am starting to hear em a bit. but nowhere near my MTR's. going to be putting the hard top on soon.
Originally Posted by vincec View Post
wow the way I hear it around JF if a jeep dose not have a Dana 44 it like driving a ticking time bomb planted right underneath your balls.
Originally Posted by WVUJeeper View Post
One of the biggest rules of fighting is: Never pick a fight with an older guy. If he's too old to fight, he'll just kill you.
Jblankster is offline   Reply With Quote
Unread 11-05-2010, 09:20 PM   #1182
1badxj
Mine started doing the exact same thing at about the 3000mi mark.......by about 4000mi on them, it became a lot worse but couldn't see any discernible wear patterns or defects. Thought as you did figuring maybe a thrown wheel weight or something. Took it into the shop, and the outside lugs had just started cuping and figure a rotation will solve it. The vibration in turns, slow speeds, and stops went away at least. Will let you guys know soon. I'm still impressed with these, but realize they need to be maintained as though they are a true mud tire and not an A/T, due to there slightly more aggressive design and larger outer lugs. Looks like ill be checking alignment and rotating every 2-3000mi instead of the normal 5-7000. Good thing I have lifetime free alignments w/tire rotation at Firestone!!!!!!!
New Toy: 2005 Rubihara #111 of 1000
Wife's: 2005 Liberty CRD
2.5"lift, Rock Lizard rock rails, Front True Trac, Rear Powertrax N0-Slip locker, & 31" Duratracs on 15x7 rock crawler rims
Tow Rig: 2003 Silver Reg. Cab Dodge 2500 2wd
5.9 Cummins (lots of mods) dyno proven 550+rwhp
1badxj is offline   Reply With Quote
Unread 11-06-2010, 01:14 PM   #1183
2006_Sport
Haven't had balancing issues yet with them, still round, no wheel shimmy...and this is on cragar steelies and 5 wheeling trips over the summer. Have about 18k on them now and still wearing very well. I'm thinking of selling them though so I can get a bigger tire (33 inch kevlars).
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| IPF|Alpine|JKS|PoisonSpyder|Truck-lite|Aussie Locker|Novak|Trail Gear|Firestik
Originally Posted by Hudson View Post
There are no women on the internet either. Learn that. It's a fact.
-Zach
2006_Sport is online now   Reply With Quote
Unread 11-08-2010, 06:15 PM   #1184
Longhorn
Do these have a 2 or 3 ply sidewall? I'm having a lot of trouble finding tires for 16" rims that aren't a load E rating. For a $180/ tire I can get 265/75R16s in a load C. This is a lot of money for an AT and I can't say I'm completely sold on them.
Longhorn is online now   Reply With Quote
Unread 11-08-2010, 07:37 PM   #1185
MPETESS10
they are 2 ply
MPETESS10 is offline   Reply With Quote
