Quantcast goodyear wrangler duratrac - Page 4 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > goodyear wrangler duratrac
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 04-27-2009, 07:00 PM   #46
SpaComponents
they do look great for an AT, several new tires have the 'look' of the sidewall lugs, but these look better than the others
SpaComponents is offline   Reply With Quote
Old 04-27-2009, 10:07 PM   #47
all3forus
I have 5 dura trac's in the 33-12.50-15 size...The ride is awesome...Load range is C...We already have almost 500 miles on them...As far as weight goes mine only took 5oz or less...We replaced the old tire that were BFG's A/T...The BFG's were great tires, but we wanted a more agressive tire and the dura tracs fit the bill...
HELP!!!!!
all3forus is offline   Reply With Quote
Old 04-27-2009, 10:55 PM   #48
Prot
Gold Member
Prot's Avatar
How would you compare noise level and ride on the street with BFG AT? How are they on the street when it is raining (not snowing) compared to BFG AT? How are they in mud compared to BFG AT?
When I bought my BFG AT, they all took 12 ounces of weight. I had them balanced at multiple shops with the same results. Road Force balance worked the best on them, but I still have a ridiculous amount of weight on them. I was told not to worry about it because that is normal for a 35" tire. Today, the allignment shop told me they could not get enough adjustment to get my Jeep perfect. I told them to do what they could. I then went elsewhere and ordered upper and lower adjustable control arms for both the front and rear. My damn tires have less than half the tread left after only 20,000 miles and are noisier than ever. They are not really noisey, but they are a lot noisier than when I got them. They certainly are quieter than the swampers I had on my 95 YJ.
So I figure, by the time I get my steering and suspension straightened out, my BFG AT will be worn out, so I am trying to get some ideas if there is something better out there for my purposes and the DuraTracs caught my attention.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/
http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html
Prot is offline   Reply With Quote
Old 04-28-2009, 10:21 AM   #49
binski
Originally Posted by CoolContractor View Post
So binski, any update on the ride and handling? I'm still trying to decide. Did you buy 4 and keep your stock spare? I'm likin' the trailer.
I did keep the MT/R spare ... figured it was "close enough" for that purpose. I now have over 300 miles on the Duratracs and I am happy with the ride. It is much smoother than the MT/R's of the same load rating (E). Much less road noise as well. A tad bit "softer" in terms of handling. No off-road or water tests yet, but I expect them to do well for me.
I did end up using 1.25" Spidertrax spacers that I had to get rid of the rub. Likely could have done it with a few washers on the steering stops, but I thought I'd try this first since I had them here ... and was reluctant to give up any turning radius. So far, they get a big "thumbs up" from me ...
Binski
[CENTER][B][FONT="Comic Sans MS"]Binski[/FONT][/B]
[COLOR="Navy"]Christian Jeep Club Member 257[/COLOR]
[COLOR="Red"]Red Jeep Club Member 245[/COLOR][/CENTER]
binski is offline   Reply With Quote
Old 04-28-2009, 10:42 AM   #50
jonzer12
Wow these things are cheap!
I called up my local goodyear dealer, royal tire and said 155 a tire (Candian dollars).
I ordered them on spot and will have them installed next Monday at 8am. BFG AT are about 190 a tire around here.
Oh yeah, 31-10.5-15 Load Range C.
2000 XJ, 5.5 lift, locked 8.8,SYE, homemade bumper/sliders,skids, other stuff
jonzer12 is offline   Reply With Quote
Old 04-28-2009, 06:48 PM   #51
all3forus
Hey Prot...These tires are quiet on almost every surface...In the rain they are doing very well so far...I switched from BFG's A/T to these, because this last set only lasted 30k miles...But the set before it lasted 50k miles...Since the JEEP needed new tires I looked all over for a tire that didn't cost over $200 and that had good winter traction...As I put some miles on them I will post more about how they handle...If you have more questions please send me a PM...
HELP!!!!!
Old 04-30-2009, 02:05 PM   #52
CoolContractor
Hey binski, how much was the rebate on your tires. I went on discount tires direct and the were $192 per tire with no rebates. Does anyone have experience with the KM2's and Duratracs? Are the KM2s worth the extra $30 to $40 per tire (x5)?
2006 TJ Rubicon
CoolContractor is offline   Reply With Quote
Old 04-30-2009, 02:51 PM   #53
rubiconjoe
where did u get the trailer? that's pretty sweet!
thanks
rubiconjoe is offline   Reply With Quote
Old 04-30-2009, 10:06 PM   #54
Crockett
I would say most certiantly not. I have about 25000 miles on my Km2 and i will need tires my the end of the summer. I was very disappointed in the life of the tire. the older BFG's lasted forever but not the KM2's
Crockett is offline   Reply With Quote
Old 05-01-2009, 07:08 PM   #55
Crockett
man I love the tires. they ride so good. but i have rotated them whenever i change my oil however i do drive back in forward to school ever week but i have only 25000 miles on them. I will be going to MTZ's next
Old 05-05-2009, 05:22 PM   #56
CoolContractor
Yo binski, update on your Duratracs?
2006 TJ Rubicon
Old 05-07-2009, 07:59 PM   #57
binski
Been in CA all week (without my Rubicon!).
I'm still thrilled with the Duratracs. The ride is very smooth and quite (compared to the MT/Rs) The real test for me will be how they do in some of our FL downpours, but unfortunately there has been very little rain here. I'm heading home on a red-eye tonite, and will be on the road with them again tomorrow, but no rain in the forecast! I really don't anticipate any bad characteristics.
This September I'm doing a 4200 mile roadtrip with my TJ and Trailer (with son). That will be the true test for wear, highway, mileage, trails, rocks and even sand and snow!
Binski
Old 05-08-2009, 12:30 AM   #58
CoolContractor
Where in CA?
2006 TJ Rubicon
Old 05-08-2009, 08:07 AM   #59
2006_Sport
I am gettting these tires in 31s hopefully this summer. I will post a mini review in this when i get them
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is online now   Reply With Quote
Old 05-08-2009, 04:47 PM   #60
CB3
Originally Posted by EarpWJ View Post
called around, 5 for $875.50 mounted and everything, good deal? 245/75/16
Also load range C or E on a WJ???
If you have the choice, go for load C.
CB3 is offline   Reply With Quote
Glock Forum
