goodyear wrangler duratrac - Page 12 - JeepForum.com
post #166 of 2232 Old 07-10-2009, 09:52 AM
2006_Sport
Originally Posted by Fargo View Post
WOW that sucks. I hope they don't all run that small.
the 31s measure out to 30.5
half inch off.. So i mean its not too bad. Like most tires
2006_Sport is offline
post #167 of 2232 Old 07-10-2009, 10:04 AM
Fargo
jonzer said his 31s measured at 30. Thats what I thought was bad. If others are measuring at 30.5 thats about what I would expect.
I'm looking at a 265/75/16 and the specs that I have seen on that size says they measure 31.7. So I'm hoping that it is close to that.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #168 of 2232 Old 07-10-2009, 10:06 AM
2006_Sport
Yeah the 30.5 measurement was taken off of tirerack and Goodyears site. If they only measure to 30 somethings up. I wish they made a 32 inch size for a 15 inch rim
post #169 of 2232 Old 07-10-2009, 10:21 AM
LazersGoPEWPEW
If you can, please measure that tire before everything is mounted up. I'm curious as to how close it is to 32".
Aren't 265/75 closer to 31x10.5?
LazersGoPEWPEW is offline
post #170 of 2232 Old 07-10-2009, 10:33 AM
Fargo
Nope. A 265/75/16 is a 32 x 10.5. The metric tires run about an inch taller for the same width of tire. Or to look at it another way they run an inch narrower for the same height of tire.
Here is a handy calculator:
http://www.redrock4x4.com/tech/tire_...&method=metric
6spd manual
Fargo is offline
post #171 of 2232 Old 07-10-2009, 10:44 AM
TowMaster
I calculated 31/10.5/15 and got 267/76/15. wouldn't that mean it would be a 31, not a 32? or is the rim size difference my cause.
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
post #172 of 2232 Old 07-10-2009, 11:04 AM
Fargo
Its the rim size difference.
The metric tires fit a 16" rim.
6spd manual
Fargo is offline
post #173 of 2232 Old 07-10-2009, 11:49 AM
LazersGoPEWPEW
Will a 265/75 fit under an XJ with a 3.5in lift?
post #174 of 2232 Old 07-10-2009, 12:19 PM
Fargo
Thats something you will have to ask in the XJ section of the forum. You might find something in the stickies section too. Try this link:
http://www.jeepforum.com/forum/f11/xj-lift-setups-read-first-post-before-replying-45602/
6spd manual
Fargo is offline
post #175 of 2232 Old 07-11-2009, 02:10 PM
jonzer12
Put some serious trail time on the duratracs today. I put a couple quick pics in the xj wheel pic thread.
These tires have impressed me alot. They are way better in mud than I thought they would be.
I ran at 20 psi and ran over all kinds of stuff with no issue. They clean out good enough.
To think I wanted general grabber AT2s. They don't hold a candle to these.
2000 XJ, 5.5 lift, locked 8.8,SYE, homemade bumper/sliders,skids, other stuff
jonzer12 is offline
post #176 of 2232 Old 07-11-2009, 05:21 PM
krawlergear
I was interested in them til I saw them in person. I need more of a mud terrain on those are mud terrains on the outside blocks but an all terrain in the center
krawlergear is offline
post #177 of 2232 Old 07-11-2009, 06:42 PM
Fargo
Can you give a link to the pictures thread? I couldn't find what you were referring to.
6spd manual
Fargo is offline
post #178 of 2232 Old 07-11-2009, 11:23 PM
jonzer12
goto the xj non-technical forum. Its a sticky at the top, I mean to say "wheeling" thread not wheel sorry.
jonzer12 is offline
post #179 of 2232 Old 07-12-2009, 10:19 AM
Fargo
It definetly looks like you had the duratracs in some mud. Here is the link for others to check it out.
http://www.jeepforum.com/forum/showt...38858&page=237
6spd manual
Fargo is offline
post #180 of 2232 Old 07-12-2009, 02:06 PM
CB3
Originally Posted by krawlergear View Post
I was interested in them til I saw them in person. I need more of a mud terrain on those (Duratracs) are mud terrains on the outside blocks but an all terrain in the center
That's why Duratracs are awesome on all terrains, including packed snow and ice; unlike mud tires which aren't very good on packed snow nor ice, unless you sipe the center treads a lot.
If you sipe the center treads of an MT a lot, you've then made the center treads more AT like.
You're complaint about the Duratracs is the feature that makes them great.
CB3 is offline
Goodyear Duratrac Tires ?? Mike in IL Tires & Wheels 24 09-25-2015 12:09 PM
Not so technical tire question "Goodyear Wrangler DuraTrac" HKB3 Tires & Wheels 9 05-12-2011 01:04 PM
Goodyear Wrangler Duratrac Blkdvll Tires & Wheels 20 12-03-2010 11:48 AM
Pro Comp xtreme alt verse goodyear duratrac xtremescootr Tires & Wheels 4 06-20-2009 09:30 PM
Who has the new Goodyear Duratrac in stock? chaznad Tires & Wheels 3 06-15-2009 08:00 PM
