goodyear MTR's anyone use em - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > goodyear MTR's anyone use em
Unread 04-16-2009, 11:40 AM   #1
txlegman
285/75/16 on Moab wheel. Did a 4" RC lift with SYE and drive shaft still have vibrations. Checked and rechecked everything fit torque specs all is good. Starts to vibrate at 50 mph. Up to 50 mph it rides great. Could this be tires?
txlegman is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 11:46 AM   #2
Imped
Imped's Avatar
I've got an eerily similar issue with my new 35" KM2s. Does it feel like a tire issue or driveline issue? Did the shop road force balance them? Where is this vibe felt? Steering wobble or under the jeep? Does it shake anything else?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 11:51 AM   #3
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yea, I use MTRs.Get your tires rebalanced.
GOLENJEEPTJ is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 11:53 AM   #4
dawnskaybug
Dont get fooled by the MT cause they suck in mud...
05 LJ
RE 4.5 SA 1inch BL
Aussie front Detroit rear 4.88s
1200 series Tractor tires (37x10)
Warn winch stinger
Lotsa trail damage
dawnskaybug is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 12:00 PM   #5
robncar
Have the shop balance them (your tires) to ZERO. You can also move tires around to attempt to isolate the offender.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 12:04 PM   #6
txlegman
Vibe feels like driveline have had the tires balanced twice. Runs good up 50 mph the it feels like bad U joints. Hardly noticeable in the steering wheel.
Unread 04-16-2009, 12:07 PM   #7
Crashnburn80
Did you dial in your pinion angle after the SYE?
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 12:14 PM   #8
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Why would you assume Goodyear's MT/R is supposed to be good in mud? They are not a mud terrain tire and they weren't designed to be... they were primarily designed for rocks and resisting cuts from sharp rocks. And just in case you didn't know, the MT in MT/R does not stand for Mud Terrain... it stands for Maximum Traction/Reinforced.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 12:17 PM   #9
Jerry Bransford
Administrator
If it's the tire shimmying, it's just a matter of the tires not being balanced well enough. Get them balanced by a shop that knows how to balance big offroad tires. And in my local Discount Tire store, the only tire balancing machine they have that can get my 35" MT/Rs balanced perfectly is their Road Force machine. I have to INSIST they use it because it takes them more time to use. Otherwise I have to come back again because if they don't use the Road Force machine, my front end will shimmy from the tires not being balanced well enough. The bigger the tire, the more important it becomes that they are perfectly balanced.
Getting Savvy...
Unread 04-16-2009, 12:27 PM   #10
03rubiconMG
Rotate the tires and check pinion angles.
If you think its a U-joint you can check your driveshaft u-joints easily by feeling for any play with your hand, its usually noticable if there is any. The front axles u-joints can be checked a similar way just more work. But use your hand to feel the play, a lot of the time you cant see it, just feel it.
the MT/Rs are awesome in the rocks, but they are loud as hell.
My 37" Iroks are quieter than my 31" MT/Rs were
2003 white rubicon on 37s
http://farm4.static.flickr.com/3374/...376a0a33_o.jpg
03rubiconMG is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 12:36 PM   #11
Pillswoj
MT/R's can be terrible to balance, when I took mine in to be Road Force balanced they felt that one should be replaced, it took 16 oz to balance.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 04:08 PM   #12
txlegman
If it is tires out of balance would this show up as a vibe from under and shouldn't I feel in the steering wheel too?
Unread 04-16-2009, 04:40 PM   #13
Pillswoj
Depends if the tire is on the front or the rear.
Unread 04-16-2009, 05:30 PM   #14
sodbuster106
I had a similar problem w/ 06 rubicon stock with MT/Rs, I changed front rotors and brakes, had the front tires balanced to zero which helped out alot, I still had a bad shimmy at 50 mph when I would hit a pothole I then put on rancho 5000 front and rear and the problems have gone away
sodbuster106 is offline   Reply With Quote Quick reply to this message
Unread 04-16-2009, 05:59 PM   #15
Yesfan70
I have 31 x10.5 (15" wheels). No problems here, other than wear a bit faster than other tires I have had (mostly all terrains).
Originally Posted by Jerry Bransford View Post
.....The bigger the tire, the more important it becomes that they are perfectly balanced.
Hey Jerry,
Is that still the same if you're running bigger wheels? Would a 35" tire on a 17"-18 wheel be just as hard to balance as a 35 on a 15"-16" wheel? Just thought I would ask, as I was curious if a tire's sectional height plays a role in balancing bigger tires.
Sorry for the off topic post.
2004 Jeep WJ
2005 Jeep TJ
Only in a Jeep
Yesfan70 is offline   Reply With Quote Quick reply to this message
