#121 | |
I'm tickled... Just bought 5 black/silver rims.
http://www.tirerack.com/wheels/WheelCloseUpServlet?target=wheelCloseUp&wheelMake= Granite+Alloy&wheelModel=GA8&wheelFinish=Flat+Blac k+w%2FMach+Lip
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar. SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage. |
#122 | |
#123 |
eeewww
I like my KM2s better ![]() ![]()
Hey hey, my my. Rock and roll will never die. - Neil Young We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson [URL="http://www.norcaljeepers.net/forum/"][FONT="Century Gothic"][B][COLOR="DarkSlateGray"]NOR CAL JEEPERS FORUM[/COLOR][/B][/FONT][/URL] [URL="http://www.jeepforum.com/forum/f20/sound-system-upgrades-speakers-amps-what-you-need-know-964324/"]Want to hear the music in your TJ, look no further...[/URL] [SIZE="4"][COLOR="White"][B]Longboard Drunk, Jeep Naked, Ski Powder[/B][/COLOR][/SIZE] [COLOR="LemonChiffon"][SIZE="1"]and finish calculus homework[/SIZE][/COLOR] |
#124 |
What pressure do you normally run on the street?
U.S. NAVY JEEP HULL # 980
GEAUX TIGERS P.S. The plane will fly! |
#125 |
Join a 4x4 Club
I've been running my Trxus M/T radials at 25 on-road, which seems to provide reasonably even wear across the tread. I go down to 7-8 PSI off-road.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#126 |
Try the chalk method for finding optimal tire pressure. It is specific to your vehicle's weight, and because it allows you to verify visually that the tread zone lays flat on the road surface, it will be easy for you to gauge exactly the right inflation pressure.
I did that w/ the BFG KM's I'm now retiring, and I'm convinced that's a big part of why I still have one half of the tread depth on them after 41K plus miles. One note though - it will normally be lower than what manufacturers recommend, and will drop your MPG, since it will increase rolling resistance. But, as I said, tread life goes way up to balance things out.
2003 Bright Silver Rubicon 285/70/17 Goodyear Kevlar MT/R's, OME, DIY bumpers/roll cage upgrades, Champion beadlocks, 33Eng BellyUp w/CV shaft, JKS BL&MML |
#127 |
Chalk method?
#128 |
Junior Member
IIRC there is the be all, end all front end alignment thread around here somewhere where I believe the chalk method is discussed.
Black Jeep Society #369 |
#129 |
The "Chalk Line Test": Draw a heavy chalk line across all the tread faces. drive slowly forward in a straight line for a few revolutions of the tire. Get out and observe the wear pattern of the chalk. If it has worn away evenly, then the inflation is correct. If either the edge or center of the line is worn first, then the tire is under or over inflated, respectively. I used sidewalk chalk - it worked great. The info above is from here, if you want to check out ALOT more info on tires: http://www.4crawler.com/Diesel/Tires.shtml
#130 |
Here's a look at the new kevlar MT/R in a 285/70/17 size. They are about 1/2" taller than the same size BFG KM's that they replaced.
![]() Just got them installed on my new beadlocks today.
#131 |
Do it right or not at all
![]() Join Date: Jan 2003
Are those real beadlocks?
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#132 |
Yep - Champion conversions on Centerline Thrusters; 17" x 8.5" w/ 3.5" BS.
Me like! ![]() Had them powdercoated in gunmetal gray.
#133 | |
SE Expedition Society
You're close by; we should tool around some time. I'd like to see how much better the tires will do aired-down on beadlocks....
Safety fast, Bill I have never been lost, but I will admit to being confused for several weeks. I was happy in the midst of dangers and inconveniences. Daniel Boone Overland Rallies & Workshops ** Overland Expo 2012 |
#134 | |
I have been wanting to get a group to go to Beasley Knob sometime - maybe we could wheel there.
2003 Bright Silver Rubicon 285/70/17 Goodyear Kevlar MT/R's, OME, DIY bumpers/roll cage upgrades, Champion beadlocks, 33Eng BellyUp w/CV shaft, JKS BL&MML Last edited by Rubicon_TJ; 04-18-2009 at 09:12 AM.. Reason: mispellings |
#135 |
Goodyear Kevlar
Finally got a chance to try the new goodyear kevlars off road today. Went up and down some buttclinching hills, thru mud and over rock finally tried some sand on the way home. Have to say I am truely pleased with the tires, love the way they handled on the trail and off, really like the looks also. Running 32x11.5x15's. Got to take care of the 3.07 gear issue next. (Yes i know it is Florida but this was done at HardRock park which is an old rock quarrie)
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
