Quantcast Goodyear MT/R w kevlar - Page 7 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Goodyear MT/R w kevlar
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 04-08-2009, 10:38 AM   #91
PDoyle
Don't get too high you'll tip over.
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline   Reply With Quote
Old 04-11-2009, 10:39 AM   #92
PDoyle
Just back from Goodyear dealer. Bad news, so far... Bought 5 33x12.50 15LT"s....
My Jeep with a new 2 1/2 " RC lift, and a 1" body lift, and installing on the (oem) 2005 TJ rims,
RUB LIKE HECK. The front tire hits the frame and the steering stabilizer on a full turn...
I can drop to the next lowest size, or the dealer is pricing spacers to install. They tell me "they install them all the time".... Sh*!!
Ideas?
PS Even with the white walls they look sweet.
Old 04-11-2009, 11:14 AM   #93
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
RUB LIKE HECK.
What is the backspacing on your wheels? I would buy wheels before I bought spacers, and spacers and steel wheels aren't too far off equal price. Short term, just adjust the steering stops.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers
JeeperDon is offline   Reply With Quote
Old 04-11-2009, 03:14 PM   #94
PDoyle
If I could get away with adjusting the stops only,man I would.
But, the back end of the tire is hitting the frame. Any reccomendations on steel rims?
I see not many people like spacers much....
I have the Ravine rims
15x8 aluminum
* 5 on 4.5" bolt pattern
* Backspacing = 5.5"
* Optional wheel with 30" tire package
* Offset = +25 mm
Old 04-11-2009, 03:22 PM   #95
PDoyle
I keep finding stuff like this when I search ......
Quote-
Rough country 2.5"SL/1.25BL combo for $389 with an additional 10% discount for being a JF member. That will give you what you need to clear 33's with out rubbing.
Old 04-11-2009, 04:11 PM   #96
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Backspacing = 5.5"
That's the problem. Most big tire trucks use aftermarket wheels that have the typical aftermarket backspace of 3.75. That's about the space you would need to clear things. Guys use those size tires on that truck model all the time without spacers because they don't use wheels with stock backspacing.
Old 04-11-2009, 09:28 PM   #97
Rubicon_TJ
Quote-
They are referring only to rubbing during full stuff.
That lift combo will work - but you might still need to adjust bumpstops front and rear. I've been running 33's (285/70/17) for several years w/ only a 2.5" OME lift. The tires would contact the front fenders when articulating, but not enough to cause any major damage. I did do the rear bumpstops, though.
For tire contact while turning you need to do as was suggested and get shallow backspacing. I know several have just posted that there are good deals on aluminum or steel wheels at Summit Racing. My $0.02 - I would suggest aluminum for better handling, due to their lower weight.
2003 Bright Silver Rubicon
285/70/17 Goodyear Kevlar MT/R's, OME, DIY bumpers/roll cage upgrades,
Champion beadlocks, 33Eng BellyUp w/CV shaft, JKS BL&MML
Rubicon_TJ is offline   Reply With Quote
Old 04-12-2009, 05:08 PM   #98
PDoyle
Thanks much for the input. Not sure where to turn with this situation. New rims?
Spacers? Run the next size down. If I look for new rims, which back space is best for my app.?
Old 04-12-2009, 05:21 PM   #99
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
A common dimension is 3.75". Friends with 35's on TJ run that with no problems.
Old 04-12-2009, 05:35 PM   #100
PDoyle
Ok. Bolt circle 4.5?
Old 04-12-2009, 05:36 PM   #101
Rubicon_TJ
Yep.
Old 04-12-2009, 06:44 PM   #102
PDoyle
ok. here's what I'm looking at on the summit website. Any bad products here I should know about?
I'm looking for a black rim and lighter color outer ring.
Any help from you guys would be greatly appreciated. Thanks much.
http://store.summitracing.com/compare.asp?Ntt=3%2E75&N=700+115&rsview=sku&Nao=40 0&Ns=P%5FSRE%5FDisplayPrice%7C0&Ntk=KeywordSearc h
Old 04-12-2009, 07:00 PM   #103
Hilldweller
SE Expedition Society
Hilldweller's Avatar
2011
Originally Posted by GrimJeeper91 View Post
A friend is a vendor at the Easter Jeep Safari in Moab and so far feedback is very positive. They are reporting better traction off road and better handling on road.
We went playing in the slop this weekend and I left it in 2wd on some heavily rutted/muddy/steep roads to see what it would do.
Not a problem, even with the trailer. Dream tires so far; hope I don't wake up.
Ummm, late warning. The 33's are a big 33...
Safety fast, Bill
I have never been lost, but I will admit to being confused for several weeks.
I was happy in the midst of dangers and inconveniences.
Daniel Boone
Overland Rallies & Workshops ** Overland Expo 2012
Hilldweller is offline   Reply With Quote
Old 04-12-2009, 07:26 PM   #104
XRussoX
Don't like the Kevlars more than the old MTRs but your scene looks like a blast.
Russo
XRussoX is offline   Reply With Quote
Old 04-12-2009, 08:04 PM   #105
hvac59
Not trying to get off track here in a tire thread, but if your looking for a good wheel on Summit website,,,, just be sure to check out these. They may be what what is used on the JT as a solid bare wheel. Powder coating in just about any color is available. The width and offset is just about anything you can amagine too. Besides, I 'm going with the 33's, just have to decide what wheels to use. I might just use the ones int this link for a little RETRO look and rattle can to match the stone white.
hvac59
http://store.summitracing.com/egnsearch.asp?N=700+4294923107+4294923106+400230+3 04840+115&Nao=40&autoview=sku#rstop
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline   Reply With Quote
Glock Forum
