Goodyear Adventurer A/T w/ Kevlar - JeepForum.com
post #1 of 12 Old 08-29-2013, 07:34 AM Thread Starter
silvanus
These A/T's were released in early August, has anyone purchased them yet??
silvanus is offline
post #2 of 12 Old 08-29-2013, 10:55 AM
WXman
It's yet another variation of the same tread. AT/S, Silent Armor, and this new one are all the same tread...with just a few tweaks. I don't understand what the hell they are doing this for. Out of the 3 though, I think the Silent Armor has the best overall pattern.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #3 of 12 Old 08-29-2013, 11:16 AM Thread Starter
silvanus
It also reminds me of the first generation wrangler of the mid- late 80's!
Just like the Film Ind., a lot of idea looping!
silvanus is offline
post #4 of 12 Old 09-15-2013, 05:32 AM Thread Starter
silvanus
Anyone purchased these yet?
I'm going to next month, just wondering what to expect??
silvanus is offline
post #5 of 12 Old 09-17-2013, 06:16 AM
WXman
Let us know how they work out and post real life pics of them up close as well. If they are like most Goodyears, prepare for a ton of weights to be hanging off your wheels when the shop gets done.
WXman is offline
post #6 of 12 Old 09-17-2013, 11:45 AM
KKiowaTJ
If they do end up having a chit ton of weight, Have them balance the wheel first before mounting the tire, Then balance from there. It should have a paint marker dot from the factory where the heavy spot is. Good luck
MOPAR!
KKiowaTJ is offline
post #7 of 12 Old 09-29-2013, 08:11 AM Thread Starter
silvanus
October 12th I'll be purchasing a set of GY Adventure 31-10.5-15's, will have pix and will be reviewing them shortly!
As for weights, hopefully GY got their act together and found out how to weave Kevlar & Steel, and QC their entire process BEFORE they hit the streets!!
silvanus is offline
post #8 of 12 Old 09-29-2013, 02:17 PM
Charley3
I don't understand your attraction to these tires, but I'm open minded. You must have your reasons. Please explain now or after you have the tires. Whenever is good for you.
My reservation about this tires tread is it looks to me like it'd be poor in mud, but it appears to me likely to be good at all else, including highway, which is important.
I'd love to hear about them after you have them, especially how they do in mud.
I'm also curious how much weight they need to balance, since the topic came up.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #9 of 12 Old 09-29-2013, 02:48 PM Thread Starter
silvanus
Strong side walls my friend!
My commute is 70 miles a day, also, I 'll be doing a lot of overland excursions and will need a tuff tire with strong sidewall protection that very few tires can give in this size!
Plus it's new and I like the tread pattern, look closely and you'll see the three block Duratrac angular pattern only tighter!
As for the mud, I've got a winch & locked at both ends, and avoid it when I can!
silvanus is offline
post #10 of 12 Old 09-29-2013, 06:50 PM
Charley3
In that case, your reasoning makes sense for your needs.
My on road DD situation is similar in that I want good highway performance for DD and road trips, so I need an AT that's good on highway, but my off road conditions are different than yours. I live in a rain forest. Even for trails, some level of mud performance is a requirement to avoid constantly having to winch, but sidewall strength isn't as much of a concern for me.
For me, Cooper AT3 are great since great on road and have decent mud ability. For sidewalls in my typical terrains, any AT load C tire is plenty tough enough.
This explains our similar, but differing opinions about ATs. We both love good DD tires, but we have different off road terrains.
Charley3 is offline
post #11 of 12 Old 10-13-2013, 06:49 PM Thread Starter
silvanus
Had them mounted today, pix tomorrow!
silvanus is offline
post #12 of 12 Old 10-14-2013, 11:15 AM Thread Starter
silvanus
I had these mounted yesterday. They balanced very well, weights are inboard on the wheel, also had the frontend aligned.
I went on some two tracks today and went where ever I pointed! Very smooth and quite!
I really like these tires and expect to have good mpg's and offroad traction in the future!
I'll be updating shortly, I have to replace my T-Case chain ( very sloppy ) after that I'll be able to comment on their performance!
silvanus is offline
