Gear/Tire Questions - JeepForum.com
post #1 of 6 Old 03-30-2011, 11:45 AM Thread Starter
RUBIJ0E
Gear/Tire Questions
Just moved to Colorado and have a few questions about tire and gear setups. Please check out my profile before responding. I know, do a search, well I have and that's where I've got most of this information and thank you.
  • Currently running BFG AT KO 285/75 16 on stock D30/44. I feel like I don't have a lot of power running these big tires especially when driving up hills.
  • Want to upgrade my gears to 4.10/4.56
  • Lockers (maybe a selectable in the front and a truetrac in the back). Could I just run the front, what are the advantages/disadvantages? Anything to stay away from? This is a DD.
  • Not sure if I want to keep the tires I have, I do like the ride but as mentioned before, I don't seem to have any power, not wanting to go bigger if anything maybe a little smaller 265/75 or 265/70. Is there and advantage in having a more narrow or wider tire when wheeling in this area given I'm new to all this.
I understand that if the right gear/tire combo is achieved you can sling any tire with moderate fuel economy. I just want something to get me up and over some difficult terrain but have enough top end to get me home.
RUBIJ0E is offline
post #2 of 6 Old 03-30-2011, 11:58 AM
KKiowaTJ
Why selectable up front? Put that in the rear and a tru-trac up front and have the best all around performance unless selectable up front too. IMO id go 4.56 or 4.88, CO has some long hills and the deeper gearing might help mpg and downshifting. Going from 3.73 to 4.10 wouldn't be worth the time and money for the 400rpms gained.
Once you get a set of gears in the axles that will pull the rig around fine no reason to drop in size. It really comes down to how you want your jeep to perform. Good luck
MOPAR!
KKiowaTJ is offline
post #3 of 6 Old 03-30-2011, 01:01 PM Thread Starter
RUBIJ0E
Kiowa, why the other way? Selectable up front was what I gathered by speaking with a few people. Personally I'd rather have a "lunch box" locker. I really don' t know the difference or how each one works. I guess I'll be doing some research. Not trying to do any extreme wheeling until I can dedicate my rig to trail riding, then it's on! Until then it seems that 4.56s and some type of lockers are what I'm leaning toward.
RUBIJ0E is offline
post #4 of 6 Old 03-30-2011, 01:47 PM
Technohead
I agree with KK; selectable (or just automatic) locker in the rear and Tru-trac in the front.
If you are in the mountains then 4.10's would be a waste. Start at 4.56 and debate whether or not to go with 4.88's.
-Eric
Technohead is offline
post #5 of 6 Old 03-30-2011, 06:16 PM
KKiowaTJ
Having the D44 in the rear helps alot. You can lunch box that and it will hold up great and save some cash, But it will make it locked all the time. I run a Detroit in the rear of mine and am very happy with it. But in snow/ice until you get used to it, Its white knuckle in 2wd. But nothing a couple mins in a parking lot wont fix and get you used to it.
If you go that route then a selectable up front would work perfect. Nothing wrong locking both axles up, But DD it IMO wouldn't be a good option. But I'm going off of where you live and "what could" happen etc. But if its open until you lock it you will be fine with one in the front.
There are many options you can do, Just have to pick the best one for your driving style and needs and go from there. Good luck
MOPAR!
KKiowaTJ is offline
post #6 of 6 Old 03-31-2011, 10:36 AM Thread Starter
RUBIJ0E
Yeah I heard Detroits or anything for that matter that are automatic make loud noises when engaging. I'm also aware about the "white knuckle 2wd" I like the parking lot idea, I've never been in a rig with locker setup so I'm kinda excited to see how all this pans out. Anyway, thanks for the advice, I'll let you know how it goes. ~Joe
RUBIJ0E is offline
tire and gear setup for tj LIFTUM Tires & Wheels 0 01-21-2006 09:29 AM
Newbie Tire, Wheel, Lift, Gear Questions linux24 Tires & Wheels 20 02-04-2005 09:34 AM
tire gear question widdowmaker Tires & Wheels 4 04-18-2004 10:41 PM
31'' tire gear question tufmar Tires & Wheels 1 02-22-2002 02:05 AM
31'' tire gear question tufmar Tires & Wheels 3 02-21-2002 12:19 PM
