Exploder Rims - JeepForum.com
post #1 of 1 Old 07-13-2010, 05:35 PM Thread Starter
pinstripefan90
1994 ZJ
Exploder Rims
I know explorer rims and jeep rims are the same 5 x 4.5 bolt pattern but since I am new to owning a jeep I was wondering if you guys have run into this issue before, I recently bought a '94 ZJ and haven't had a chance to register it yet but the other day after work I decided to throw my set of exploder rims I had laying around on it w/ my 31's so I bolted them up, threw the dealer plate on the jeep and drove it out of the shop, as I was stopping I herd a clunking noise coming from the rear that sounded like I left a caliper bolt out or something so I pulled over and look under the jeep, nothing was obviously falling off or broken so I turned around and went back into the shop and threw it in the air. I found nothing loose and then when checking everything out I realized that the clunking was the rotor moving and hitting the studs, so I know the explorer rims have different backspacing and even though they are tight they aren't clamping down the hat of the rotors so I think i'll just buy a set of wheel spacers so I have something to clamp the rotors down w/ but I am wondering what have you guys done if you have been confronted w/ this problem...thanks
- Jake
pinstripefan90 is offline
backspacing , ford 8.8 , rims , rims spacer backspace
Exploder Rims pinstripefan90 Tires & Wheels 0 07-11-2010 07:58 PM
Not a jeep, but it looks like we broke my buddys exploder locohosa General Jeep & Off-Road Equipment 22 08-28-2009 03:05 PM
Exploder driveshaft ? crusher242 Engines & Drivetrain 1 11-27-2008 07:31 AM
Tools to remove 8.8 from Exploder??? Airborne4X4 Engines & Drivetrain 5 02-24-2008 09:11 AM
exploder 8.8 Quan General Jeep & Off-Road Equipment 18 11-07-2002 08:07 PM
