Drive Shaft - JeepForum.com
post #1 of 3 Old 04-24-2004, 09:54 AM Thread Starter
DIESEL
Drive Shaft
what do you about your drive shafts w/ a 4 inch lift.
DIESEL is offline
post #2 of 3 Old 04-25-2004, 03:15 PM
yj_magnus
yj_magnus's Avatar
You could do a transfer case lowering kit, which will probably take care of the vibration. (each jeep seems to handle a lift a bit differently) That is the cheap fix. If you don't care about cheap, the best way to go is a Slip Yolk Elimiator, CV Drive shaft, and the right shims on your rear spring mounts to turn the pinion angle up, pointing directly at the yolk output.
Tom Woods is the shaft I went with and they have some tech pages on their site to clarify how the drive line angles should be in both cases (standard shaft with 2 U joints or a CV style double cardan shaft)
See, its like my grandaddy use to alway say "When hell is full, the dead will walk the earth"
yj_magnus is offline
post #3 of 3 Old 04-27-2004, 06:26 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
What kind of vehicle and t-case do you have.
Here is a link to TomWoods geometry 101, good read
Matt
MSHarnett is offline
CV drive shaft for YJ xcnick38 Engines & Drivetrain 1 11-23-2008 02:30 PM
CV Drive Shaft GDTIME Tires & Wheels 0 07-28-2008 05:21 PM
Drive Shaft Paul08Wrangler Engines & Drivetrain 2 02-12-2008 11:10 AM
Drive Shaft Question Paul08Wrangler Engines & Drivetrain 4 12-26-2007 12:56 AM
drive shaft help?? 360wrangler Engines & Drivetrain 5 12-30-2006 10:22 PM
