do rubicons come with a stock lift? - JeepForum.com
post #1 of 9 Old 06-03-2008, 06:08 PM Thread Starter
ryans_04_rubi
I was looking in to a 2.25 BB and i was told that my rubicon had a 1.5 suspension lift stock. If that is true do i still need to get a BL to clear 33s
ryans_04_rubi is offline
post #2 of 9 Old 06-03-2008, 07:12 PM
FuzzyDolly
As far as I know, Rubicons don't come with a stock lift. The difference in height is due to Rubicons coming with taller tires. My X came with 215/75R25 which I believe are about 28" tall. The Rubicons come with 30 or 31" tires from the factory. That will make the Rubi sit about 1.5" higher
Joe
2005 Solar Yellow X
2" Skyjacker BB - 31X10.5\15 Cooper STT
FuzzyDolly is offline
post #3 of 9 Old 06-03-2008, 07:23 PM Thread Starter
ryans_04_rubi
that is what thought but my 31s have as much clearence as a sport or a x with smaller tires
post #4 of 9 Old 06-03-2008, 07:34 PM
BM20
I just lifted my Rubicon and the Stock Rubi springs are the same size as the Stock springs from my previous 2000 Sport.
RUBICON Tomb Raider #953
With a Few Extras...
BM20 is offline
post #5 of 9 Old 06-03-2008, 08:26 PM Thread Starter
ryans_04_rubi
allright thanks
post #6 of 9 Old 06-03-2008, 08:48 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
there is no lift. Rubicon's did however use the stiffest spring set that Jeep had made with nitrogen charged shocks stock. those things coupled with the taller Goodyear MT/R tires make them appear taller than other jeeps
My builds:
and
or follow us on
spyder6 is offline
post #7 of 9 Old 06-04-2008, 06:38 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
From the TJ Forum FAQ and notice who made the post:
Originally Posted by JeepEngineers View Post
Tires would be the only part to influence lift. There is no suspension height difference.
Wheelin98TJ is offline
post #8 of 9 Old 06-04-2008, 08:39 PM Thread Starter
ryans_04_rubi
i did buy it used ill have to look thanks
post #9 of 9 Old 06-08-2008, 09:06 PM
CB3
I heard all sorts of things. Here is the correct info to the the best of my knowledge. Rubicons come with stiffer springs that make them sit a bit higher. I heard all sorts of conflicting info on how much higher that from local 4x4 shops, tire stores, and at this forum.
Finally, in exasperation, I drove my Rubi to the local Jeep car lot and measured ground clearance to body just behind front fender.
My Rubi with stock springs sat 0.75" higher than a non-Rubi. I ran 33 X 11.5 tires for an entire year with no lift and it never rubbed anything, except a bit on swaybar when turning to full lock.
So based on my actually measuring my Rubi and a Sport of similar model year, and taking into account difference in tire size, I found the Rubi suspension goes apparently give about 0.75" of lift, apparently due to stiffer spring rates. Technically that is not a lift, but it does sit higher in regard to suspension, plus more additional height from tires.
So if you installed a 2" aftermarket lift, you'd be 2" higher than a stock non-Rubi, which would be 1.25" higher than a stock Rubi suspension.
For another example: If you installed a 3" aftermarket lift, you're Wrangler would sit approx 3" higher than a stock non-Rubi, which would be 2.25" higher than a stock Rubi suspension.
I'm talking suspension height above. Any difference in tire height would be additional change in height.
CB3 is offline
rubicons w/ 265/75/16 claytonandson Tires & Wheels 5 11-12-2009 07:32 PM
What years did Rubicons have the silver vs. polished Moabs? SteelBlueTJ Tires & Wheels 0 12-08-2008 07:36 AM
What are the stock specs for rubicons? oneslowz28 Tires & Wheels 7 09-18-2007 08:12 AM
will lift shocks work w/ stock lift. BlazedXJ Tires & Wheels 1 06-21-2006 01:56 AM
Any Rubicons W/ R.E. 3.5" standerd kit afish Tires & Wheels 5 07-14-2004 11:35 AM
