Do I need Wider Rims for what I want? - JeepForum.com
post #1 of 5 Old 07-26-2012, 04:09 PM Thread Starter
DrunkenBear
Hey Guys,
I'm kinda new to the upgrading bit and I am looking at buying some new Rims/Wheels for my Stock 2006 Jeep Wrangler Sport.
My plan is to get a wider set of tires on my Jeep. And the first part of that process is by getting newer rims with 4" back space. So I'm looking at the CRAGAR 397 series rims. I am unsure to get the 15x8 or 15x10. I will need these 30x9.5R15(stock) tires on these new rims before I get my Lift and tires. Will the 30x9.5 tires fit the 15x10? or should I just go with the 15x8 and max them out?? (end game plan is a 2" lift and a ~32x12.5 tire).
I could use all the input I could get...
DrunkenBear is offline
post #2 of 5 Old 07-26-2012, 08:39 PM
222Doc
222Doc's Avatar
do not go 15x10inch rims. 15x8's
222Doc is offline
post #3 of 5 Old 07-26-2012, 08:55 PM
diddy2003
^+1, 15x8s
diddy2003 is offline
post #4 of 5 Old 07-29-2012, 12:08 AM
ltrail
1984 XJ Cherokee
The 15x10 will make the tire stretched like you see on low riders. Width close to stock is best.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 5 Old 07-29-2012, 03:36 PM
castorriver
15x8 like the other guys said.. it will keep your rim farther away from rocks and other sharp objects. Also with the wider rims (15x10) you'll get mud and sticks jammed down into the bead causing a slow leak... that happened when I went wheeling with my stock tires and wheels in my YJ. Tire was flat the next day and I had to get it cleaned out at a tire shop.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
wider rims spyder6 Tires & Wheels 1 08-13-2007 02:25 PM
is wider better? joeygeep Tires & Wheels 1 02-07-2007 12:42 PM
Stock rims and wider tires JohnW Tires & Wheels 10 11-04-2005 12:30 PM
Is Wider better? Johnmac Tires & Wheels 12 10-12-2005 11:16 AM
Guys running tires wider than 12.5 What size rims? Dave Taylor Tires & Wheels 7 02-24-2005 08:33 AM
