Did Jeep make 16 x 7 wheels with 5 on 4.5 bolt pattern? - Page 2 - JeepForum.com
post #16 of 48 Old 05-12-2013, 09:12 PM
WhiteOut
WhiteOut's Avatar
The ZJ Timberline wheels should fit the bill.
WhiteOut is offline
post #17 of 48 Old 05-13-2013, 12:09 AM Thread Starter
Charley3
Originally Posted by timberlake74 View Post
any idea what specific vehicles the "icon" wheel comes from
Some later XJs. Possibly some TJs?
I think some later ZJs.
I don't think any KJs because the KJ is ( I read somewhere) front wheel drive (when in 2wd) and always uses 16x7 with 5.5 BS because that is what is needed for its front wheel drive.
Ecco, Grizzly, Icon and other 15 x 7 and 16 x 7 wheels for rear wheel drive XJ, ZJ, TJ are always 5.25 BS, IMO. That's in regard to 7" wide wheels for those models of rear wheel drive Jeeps.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #18 of 48 Old 05-13-2013, 06:29 PM
mschi772
1997 XJ Cherokee
I can show you KJs that came stock with Icons (for example, look-up early Liberty Renegades; many of them had Icons). Can you show me TJs or ZJs that had them from the factory? It doesn't really matter anyway because YJ, TJ, XJ, ZJ, and KJ all have the same bolt patterns, so they can all share wheels easily.
Whatever you read somewhere was all kinds of wrong. KJs are RWD. MKs are the only FWD Jeeps. The KL (2014+ Cherokee) will also be [kinda] FWD.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #19 of 48 Old 05-14-2013, 12:24 AM Thread Starter
Charley3
Maybe I got my alphabet soup mixed up. Which Jeep is a KJ? In plain English please.
Charley3 is offline
post #20 of 48 Old 05-14-2013, 05:05 AM
mschi772
1997 XJ Cherokee
XJ = 84-01 Cherokee
ZJ = 93-98 Grand Cherokee
KJ = 02-07 Liberty
YJ = 87-95 Wrangler
TJ = 97-06 Wrangler
MK = Compass and Patriot
KL = 14+ Cherokee
mschi772 is offline
post #21 of 48 Old 05-14-2013, 11:03 AM
timberlake74
Later XJs and some early KJs.
so an xj would be a cherokee and a wj is? im not to up on all the body styles and do you have an idea on the years never mind just saw all the follow up on in the question thanks guys that can help in the junk yard crawl
timberlake74 is offline
post #22 of 48 Old 05-14-2013, 01:09 PM Thread Starter
Charley3
Huh. I don't know much about Liberty. I had read their wheels are always 16 x 7 with 5.5 BS.
While shopping for stock 16 x7 with 5.25 BS, it appeared to me that Liberty wheels are indeed 5.5 BS.
In any case, Icon wheels are 16 x 7 with 5.25 BS. I'm interested in all stock wheels with those specs specifically.
Charley3 is offline
post #23 of 48 Old 05-14-2013, 02:01 PM Thread Starter
Charley3
Here are Liberty wheels called Renegade that look like Icon wheels. Like all other Liberty wheels I've seen, they are 16 x7 with 5.5 BS.
http://www.jeepforum.com/forum/f125/...heels-1513116/
Is it possible that you saw these Liberty wheels and thought they are Icons?
Icons are (as I'm sure you know) 16 x 7 with 5.25 BS.
Charley3 is offline
post #24 of 48 Old 05-14-2013, 07:19 PM
mschi772
1997 XJ Cherokee
Those ARE Icons. The seller calls them Renegade wheels because they're FROM a Liberty Renegade--much like how Moabs are often referred to as Rubicon wheels because they came on Wrangler Rubicons. The ad makes no mention of the backspacing, so why do you think they're 5.5?
Anyway, why is 0.25" backspacing such a big deal for you? I've seen guys mount KJ wheels that have 5.5 BS on XJs without spacers just fine. If you're really set on that exact size, you're stuck with Icons and ZJ 16" wheels. 5" or 4.75" BS, since that what you said you want in your OP, will have to be achieved with either aftermarket wheels or with spacers.
mschi772 is offline
post #25 of 48 Old 05-15-2013, 12:51 PM Thread Starter
Charley3
I'm not saying you're wrong, but here's my explanation.
I saw "Renegade" wheels for sale at a website that sells new OEM and OER (OE Replacement) wheels. They said 5.5 BS.
They also had Icon wheels for sale and said 5.25 BS.
I may want to run 31 x 9.5 R 15 (245) tires on Icon wheels in future. It'd be a tight fit between tires and LCAs, but I think possible with round LCAs.
Edited in Later: It's the stock swaybar that might rub tires, not the stock LCAs.
I will install a Currie Anti-Rock swaybar in future to improve ride quality and flex, and it will also improve tire clearance during turns.
Charley3 is offline
post #26 of 48 Old 05-15-2013, 03:37 PM
mschi772
1997 XJ Cherokee
Well, a nice set of hub-centric spacers could be another way for you to work it out. It's also possible to adjust the steering a bit to stop it sooner; you lose a little turn radius, but might eliminate the risk of rubbing a LCA.
mschi772 is offline
post #27 of 48 Old 05-21-2013, 04:53 PM Thread Starter
Charley3
I have learned that it's the stock front sway bar that larger tires (on stock wheels) might rub. It's not the LCAs that tires might rub.
What I need to do is install a Currie Anti-Rock front sway bar because it has more tire clearance, better ride quality on an off road, and more articulation.
Problem solved.
Then I'll have no problems running 31 X 9.5 R16 (245/75R16) tires on stock Icon 16 x 7 with 5.25 BS and full turning radius with no rubs on sway bar or LCAs.
Probably the same deal with 31 X 10.5 R15 on stock 15 x 8 with 5.5 BS and full turning radius with no rubs on sway bar or LCAs.
Either of those tires on stock wheels (with low lift and no bump stop extension) might, or might not, rub stock flares during sharp turns while articulating. If it did rub, then I'd get Notch flares, which look stock (but larger), are paint-able. (Notch flares clear 31 X 10.5 on stock XJ)
In addition, I'd also install round LCAs because that does increase LCA clearance a bit, and I will get excellent Duraflex rubber joints that increase flex as much as a JJ and ride softer than stock rubber bushings. Once the sway bar is out of the way (stock SB replaced by AR), the next things that could rub are LCAs. I will not adjust steer stops because I want full turning radius. I'm thinking Metalcloak LCAs with Duraflex bushings.
Charley3 is offline
post #28 of 48 Old 06-19-2013, 05:24 PM
habbyguy
I think Ecco and Grizzly are 15 x 7 with 5.25 BS.
The Grizzly wheels are 15x7, but the confusion comes in because there are TWO types of Canyon rims (I have a set of each).
The Canyon rims from the ZJ ('93-98 Grand Cherokee) are 15x7, and have a slightly darker gray paint on the slots. The Canyon rims from the Wranglers (not sure which years offhand) are 15x8, and are a little lighter (color-wise). I believe both have 5.25" backspacing.
They both fit well on a Cherokee.
If it helps, here are some photos of the Grizzly rims I used to have on my XJ (same dimensions as the ZJ Canyons), before and after adding 1.25" spacers. The last photo is with a set of Wrangler Canyons, with the spacers still in place. Hope this gives some others a visual reference for how these wheels fit. Note: the tires in the photos are all 31x10.5x15's.
habbyguy is offline
post #29 of 48 Old 06-23-2013, 08:15 AM
silvanus
KJ winter wheels they're steel, a lot cheaper than the Icon and are 16x7, same as WJ, but 5on4.5 bolt pattern!
silvanus is offline
post #30 of 48 Old 06-23-2013, 03:07 PM Thread Starter
Charley3
Good to know, but I prefer aluminum wheels (Icon) because they look better and IMO give better gas mileage than steel wheels.
Charley3 is offline
