Compatible Tire sizes for 2000 Cherokee Sport - JeepForum.com
post #1 of 6 Old 12-17-2008, 06:45 AM Thread Starter
vodka
I've been searching the net in hopes to find a list of supported tire sizes [w/o any modifications] for my 2000 Jeep Cherokee.
It came stock with 225/75R15s and I need to get winter tires and found an affordable set of 215/75R15s.
I've seen other posts that show some of the Cherokees coming stock with 215s but I can't find any information on whether switching from 225s to 215s is going to cause any issues.
If anyone can point me to a resource or answer this I would be greatful. What would be a good size for a winter tire? (when I watch rally racing I see the cars using thinner tires in the snow - would the same principle apply?).
Thank you!
vodka is offline
post #2 of 6 Old 12-17-2008, 08:18 AM
aleydic
thinner tires are much bettter and that tire size should work great for winter
jeeps are for exploring the off road
until you change them thats all they will do..
aleydic is offline
post #3 of 6 Old 12-17-2008, 08:51 AM
1996BlackXJ
Well skinny tires cut through the snow instead of floating on top. That's the reasoning behind that. The only thing that I can see that may be a problem is your speedometer might read a couple mph faster than you are actually traveling. That's no biggy though.
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #4 of 6 Old 12-17-2008, 09:02 AM
p2000sk
My 2000 Sport came factory with 215's, I quickly replaced them to 225/75/R15 BFG All-Terrain. It seems like the tire selection at 225 is greater. NO ISSUES WITH ME CHANGING THE TIRE SIZE. I think your stuck on getting an answer about a great winter tire "size". I don't think you have much choice for a specific tire if your not changing the rims. Everyone is right, thinner is better for the snow and I have not had any issues. Then again you live in Canada and I New Jersey.
p2000sk is offline
post #5 of 6 Old 12-18-2008, 09:21 AM Thread Starter
vodka
Thanks for all your responses. Does that mean that if I get the 215/75/15 tires I cannot install them on my existing stock rims on which I have 225/75/15 tires and I need new rims?
vodka is offline
post #6 of 6 Old 12-18-2008, 09:00 PM
FransWhiteXJ
To answer a few of your questions:
1. My '00 XJ's door jamb sticker states the stock tires are 215-75-15, but the Jeep came from the factory with the optional 225-75-15.
2. You can mount either tire on your rims (or buy dedicated rims (Soft-8s) for the winter tires>>that way you can change over spring-fall for free!!).
3. You won't have any problems switching tires. Smaller tires will make your speedo read "faster" and will numerically increase your axle ratio-better for towing, etc. In the winter, I run 225-75-16s snow tires ("borrowed" from my GMC full-size pick-up) on Soft-8s and the speedo is dead nuts compared to various GPS measurements.
4. Skinner tires are better for snow conditions, as stated above.
5. As far as snow tire selection, I am running Dean Wintercat SST studded snow tires (I snowplow with my XJ). They have awsome traction (even probably without studs). Dean tires are made by Cooper, but cost less. The Wintercats are a knock off of Cooper Discoverer M+S, which are highly rated in the snowplow industry. I used to run Dean Wintermaster Plus, (50,000 miles winter & SUMMER use), but they are no longer made in 225-75-16 size. Although I bought them local, check this link: http://www.vulcantire.com/privtire.htm
Fran
'00 White XJ; D30 w/Aussie & Alloy USA, 8.25 w/open diff, Hella 700FF w/100W bulbs, 225-75-15 Mastercraft AT2, Sno-Way ST-90 snowplow, Air-Lift springs-front/Max-Aire shocks-rear
FransWhiteXJ is offline
2000 Cherokee Sport Transmission Problem Konz Engines & Drivetrain 1 12-09-2009 03:27 AM
What is the maximum tire size I can use on a 2000 Cherokee Sport 4.0 I6? hsbc35pos2 Tires & Wheels 2 11-21-2009 05:19 PM
87 Cherokee Pioneer Tire Sizes? Little_Pioneer Tires & Wheels 0 10-19-2009 09:52 AM
Advice on stock tire sizes for my '97 cherokee zzrich Tires & Wheels 9 07-27-2009 06:30 PM
2000 Jeep Cherokee Sport spiritwolf68 Tires & Wheels 6 11-10-2004 12:11 AM
