Coil Spring Spacers: Good or Bad? - JeepForum.com
post #1 of 12 Old 10-11-2006, 01:48 AM Thread Starter
Texan in Cali
Looking into giving my TJ a little bit of a boost (1.75" or 2"). I have had lifted vehicles in the past (just not jeeps) and always replaced the leaf or coil springs to do this but am very drawn to the money savings associated with spacers. Can anyone tell me whether or not this is a safe and long lasting way to lift a TJ? Will anything else need to be modified like a drop for the transfer case or swap out the pitman arm?
Texan in Cali is offline
post #2 of 12 Old 10-11-2006, 02:11 AM
olds442
olds442's Avatar
if your lifting it with the spacers from stock you wont need to change anything, and they are prefectly fine to use
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
olds442 is offline
post #3 of 12 Old 10-11-2006, 02:14 AM Thread Starter
Texan in Cali
what would fit under that lift comfortably? I don't really care for the overstuffed wheel wells look. Perhaps 31's or 32's?
post #4 of 12 Old 10-11-2006, 02:19 AM
olds442
olds442's Avatar
hmm not sure, i have a XJ, but ive seen quite a few TJs with 2in lifts and 33s, but i would stick with 31s or maybe 32s, that being you dont want that stuffed look
Family Wheelin...
VT
olds442 is offline
post #5 of 12 Old 10-11-2006, 02:22 AM Thread Starter
Texan in Cali
thanks alot for your help
anyone else with any input please post. your advice will be greatly appreciated.
post #6 of 12 Old 10-11-2006, 02:33 AM
got_4_lo
a 2" BB will clear 31's nicely. check out the sticky on the TJ section for pics of that setup.
-Shayan A.K.A: Sean
Originally Posted by DesertTJ
I came home to be spit on and protested against in Boulder, Colorado. Most of the people have no clue. And that's why we do what we do. We give up our freedom so they can enjoy their freedom.
got_4_lo is offline
post #7 of 12 Old 10-11-2006, 02:34 AM
drew and not u
drew and not u's Avatar
Spacers can be very useful, though they are not a good way to add lots of lift. For 2" or less they're definitely fine. They won't give you as much flex as new spings, but they will give you the tire clearance you want on the cheap. I used a set of 1.5" spacers in the front of my XJ to level it out with the back leafs.
<- specs go over there, man!
drew and not u is offline
post #8 of 12 Old 10-12-2006, 03:36 PM
runfrumu
i got a spacer lift, and on my passenger side today i hit a speed bump and heard rubbing, my spring has shifted off-center of the spacer and is causing it to rub when it hits a good bump. mines got a 2 inch with 33's, heres a pic to give you an idea of what it looks like.
anyone have any info on how to keep the spring from shifting on the spacer?
runfrumu is offline
post #9 of 12 Old 10-12-2006, 03:46 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
this is my friends TJ on 32s with a 2" BB
take that as you will
hint: do 32s
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline
post #10 of 12 Old 10-12-2006, 05:02 PM
fro-nig
The Mighty Fro-nig
fro-nig's Avatar
hey will what size lift and tires are you running on your xj in that pic?? also how wide the tires are too
2000 Cherokee Sport
4.0/AW4/NP231
3" Rusty's Lift (4" actual)
31x9.5 Super Swamper TSL Radials on stock wheels
FOR SALE: $5000 OBO
1995 dodge ram 1500 4x4
8" suspension lift
DC long arm kit
35" baja claw radials on 15x10 rockcrawler wheels
fro-nig is offline
post #11 of 12 Old 10-12-2006, 05:43 PM
Sanford_
Wow, that's some major flex for a bb HeavyMetal! Does he have a inch BL on that tj too?
Sanford_ is offline
post #12 of 12 Old 10-12-2006, 11:33 PM
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
theyre the same tires / lift i have now, 33x10.5s on the RE4.5. but in that old pic theyre on stock backspacing. it was like right after i got it basically ( that setup)
i forgot about that, theres a good chance he had his 1" body lift on at the time of the pic
Coil Spring Spacers Jeep4x4FLA Tires & Wheels 2 08-04-2008 02:11 AM
Coil Spring Spacers R. Potts Tires & Wheels 7 03-14-2007 07:20 PM
Coil Spring Spacers? Incadude General Jeep & Off-Road Equipment 4 02-27-2007 04:09 PM
coil spring spacers? blue4banger Tires & Wheels 1 10-25-2002 10:25 AM
