Cherokee Sport - What other Jeep wheels will fit ? - JeepForum.com
post #1 of 12 Old 11-24-2008, 08:31 AM Thread Starter
NYSLC93
First post here....I just bought a 2000 Cherokee Sport for a winter ride. I've wanted one for a long time, and I'm excited to have one.
The bold pattern is 5x4.5, correct? What is the offset?
In any event, what other Jeep wheels (i.e. Wrangler and/or Grand Cherokee) are a direct fit on the Sport?
Any help is appreciated!
NYSLC93 is offline
post #2 of 12 Old 11-25-2008, 10:02 AM Thread Starter
NYSLC93
Will 235 width fit fine?
NYSLC93 is offline
post #3 of 12 Old 11-30-2008, 05:54 AM
fasassvalk
canyon
Jeep sahara 8 inch Canyon wheels fit and look great on a cherokee,
I have had two different cherokees and used canyon wheels on both
you can fit 30/9:50/15 A/T tires under a stock height cherokee using these wheels.
fasassvalk is offline
post #4 of 12 Old 11-30-2008, 06:04 AM
fasassvalk
235 Vs
A 235 and a 30/9:50/15 is very close to same height.
if you use a stock 8 inch jeep wheel it keeps the back spacing where it should be. if you use a aftermarket wheel with alot of offset , moldings will rub when the body rolls and dips.
I made that mistake on one cherokee, using black steel slotted wheels with alot of back spacing and it stuck the wheel further out to the edge of the fender and looked good but the rear rubbed when hitting bumps or when body rolled.
8 inch jeep wrangler sahara canyon wheels are about the best looking wheel from the factory.
post #5 of 12 Old 12-01-2008, 01:43 AM
ep191
I dont know about most of the newer jeeps but any tj wrangler up to 2006 will have 5 on 4.5 pattern and any grand cherokee up to 1998. The newer jk wranglers i believe are 5 on 5 or 5 on 5.5 and i dont know about the newer grand cherokees.
ep191 is offline
post #6 of 12 Old 03-30-2012, 09:42 AM
CJSport
I have a 2001 cherokee would a set of 2011 or 2012 wrangler wheels fit its lifted thats all i know.
CJSport is offline
post #7 of 12 Old 03-30-2012, 12:04 PM
biffgnar
biffgnar's Avatar
As the post immediately prior to yours makes clear, those are a different lug pattern and will require adapters.
biffgnar is online now
post #8 of 12 Old 03-30-2012, 01:18 PM
WXman
Jeep Liberty, Jeep Wrangler through 2006, Jeep Grand Cherokee through 2004.. all of these wheels will fit a Cherokee.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #9 of 12 Old 04-01-2012, 10:59 PM
LouC
2007 WK
The Grand's bolt pattern changed in 99 so only up to 98 for wheels to fit a Cherokee. Wrangler till the new style came out I think in 07. A lot of parts are very similar from the ZJ to the XJ, brake rotors, calipers, etc.
LouC is offline
post #10 of 12 Old 04-03-2012, 06:04 AM
Millermagic
Jeep with NO problems:
YJ, TJ, ZJ (93-98 Grand), XJ (obviously ...), Liberty (UNTIL 2007 ... 2008 uses a different hub center and the wheels won't fit without boring the center).
If you are looking for 16s with a direct fit the Dodge Intrepid has the same bolt pattern and center bore as our Jeeps do.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #11 of 12 Old 06-19-2015, 09:37 AM
JeepasaurusRex2
Do the 16s from a classic fit the sport also?
JeepasaurusRex2 is offline
post #12 of 12 Old 06-19-2015, 10:01 AM
biffgnar
biffgnar's Avatar
Yes
tire/wheel packages under 500? 99 cherokee sport 15" wheels easy_roller Tires & Wheels 1 08-20-2009 09:51 PM
HELP WITH 3'' LIFT KIT 99 Jeep Cherokee Sport Habib66 Tires & Wheels 6 07-09-2009 05:45 PM
changing alternator jeep cherokee sport 4.0 Joe11 Engines & Drivetrain 0 06-18-2009 02:17 PM
95 Cherokee Sport - Will 09 Patriot Wheels Fit? timbermx Tires & Wheels 7 04-24-2009 01:34 AM
2000 Jeep Cherokee Sport spiritwolf68 Tires & Wheels 6 11-10-2004 12:11 AM
