Chalk test?? I'm not driving at 16 PSI!!! - Page 4 - JeepForum.com
post #46 of 49 Old 03-05-2012, 08:26 PM
castorriver
I still don't understand why you guys think the OP did the test wrong.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #47 of 49 Old 03-05-2012, 10:32 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Because the 16 psi the chalk test was indicating to him is an unreasonble pressure to run his tires at. Fortunately he had the common sense to know 16 psi was inappropriate.
As I have said many times, the chalk test is responsible for many tires being run underfilled which causes them to run hotter... which is unsafe due to the greater potential for tire failure from an overheated tire.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #48 of 49 Old 03-06-2012, 05:47 AM Thread Starter
PredatorNC
2010 JK Wrangler
<OP The chalk test interested me...that's why i tryed it. Even at 16 psi the chalk thru the center was worn off and the chalk on the outsides was worn, but not like the center, so i would guess that to get "the full contact" it would have been somewhere around 12 psi. I searched the forum for more info and didnt get a whole lot, thus i started this thread, if for nothing more than another post for noobs like myself that didn't know a whole lot about where they should sit with the air pressures. I would have no problem at all running 12 psi on the trail...i currently sit at 24 psi and its comfortable for me and my very stock TJ with no weight from aftermarket bumpers, spare tire and i have a soft top. One day when i have all that stuff then yeah, i may run another 2-4 psi....
Again, Thank you all for the imputs...more info here, less mistakes out there! lol
PredatorNC is offline
post #49 of 49 Old 03-14-2012, 08:40 AM
tjtrucker
I run 26psi for my 33" duratracs, the very outer edge doesn't touch the road, but still has a good contact patch area, and the ride/control is very good
tjtrucker is offline
33 , chalk , tire pressure
Chalk test results UltimatE YJ Wrangler Technical Forum 5 10-25-2010 04:34 PM
Chalk test rockit TJ Wrangler Technical Forum 17 09-18-2007 03:39 PM
Test Driving: What to look for? chitarra YJ Wrangler Technical Forum 30 05-07-2007 09:52 AM
Test driving a TJ? Marty315 TJ Wrangler Technical Forum 2 08-10-2003 09:24 PM
FAQ or How-to for test driving a TJ? duckyjp TJ Wrangler Technical Forum 1 02-19-2003 08:51 PM
