Cant Remove Completely Stripped Lug Nut - JeepForum.com
post #1 of 8 Old 01-16-2010, 02:02 PM Thread Starter
KrawlinAllOver
I had my wheels and tires rotated not to long ago and now that im installing new tires and wheels i need to remove my wheels and on one of the wheels the lug nut is completely stripped out like u cant get it off with and tools. any ideas on how to get it off??
KrawlinAllOver is offline
post #2 of 8 Old 01-16-2010, 02:32 PM
zachjf
I had the same problem after a trip to Les Schwabs, ended up using vise grips and pulling straight back while twisting side it side till I got some space then used a claw hammer to get more tension while twisting some more. Lots of sweating and cursing later I got it off. If that doesn't work you can always use a dremel and cut off wheel.
Needs parts?
PM
or
zachjf is offline
post #3 of 8 Old 01-16-2010, 03:51 PM
1996BlackXJ
Find a touch impact socket one or two sizes smaller that you aren't afraid to say good bye to. Smash it onto the nut with a hammer. Remove. If you put the socket in a vise you may be able to use a punch to knock it out.
I had to do that with my lug nuts that need a key...lost the key and they are 13/16" outer diameter for the regular nuts, so I used the 7/8" side of my tire iron and tapped in on and got them off, when I loosened them I wiggled the tire iron off the lug nut then unscrewed by hand.
Good luck.
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #4 of 8 Old 01-16-2010, 04:14 PM
Mooseknuckles
If it's a 3/4 lugnut, grab an 18mm socket. basically do what blackxj said, pound it on and pray.
The Green Machine 2005 Wrangler Sport, 31" Michelin LTX A/T's on 15x8 Cragar V5's
The Build Thread:
HAYTHANKS to Rammer500 for the Membership Upgrade!
Mooseknuckles is offline
post #5 of 8 Old 01-16-2010, 04:19 PM
COLOUXJ
2010 JK Wrangler
or you can take it to a discount tire, we have stuff designed for it, like taking off wheel locks that are perfectly smooth, and i think we would do it for free, but if you want to try it on your own, do what they said above and to get the lug out of the socket put it on the ground and hit it with a hammer on the side, do this a couple times and it should come out.
COLOUXJ is offline
post #6 of 8 Old 01-16-2010, 04:23 PM
Robyjuk
1987 YJ Wrangler
go to you local autoparts store and see if they can get or sell you a locking wheek nut remover ,its basically a socket with a reverse thread in it that will bite into whats left and remove it, they sell them over here in the UK and you best use them with an air impact driver for best results.
http://www.halfords.com/wcsstore/Hal...400-696823.jpg
thats what they look like
Robyjuk is offline
post #7 of 8 Old 01-16-2010, 04:23 PM
zachjf
I may be wrong but I think he means the threads are stripped off inside the lug itself and its just spinning, happens when they get get over tightened and the lug doesn't snap off
Needs parts?
PM
or
zachjf is offline
post #8 of 8 Old 01-16-2010, 04:46 PM
KKiowaTJ
Use a pneumatic cut-off wheel. I have done it many times and no problems. Just split it right down the middle and use a chisel and hammer to finish the job. Good luck
MOPAR!
KKiowaTJ is offline
CJ7 body mounts completely rusted out cj7Sswampers General Jeep & Off-Road Equipment 6 01-24-2010 10:37 AM
Completely New Audio System Thexonexkid Audio, CB & Ham Radios, GPS, & Electrical 6 12-03-2009 10:32 AM
Completely rewiring the Jeep... Waderacin Audio, CB & Ham Radios, GPS, & Electrical 1 08-14-2009 09:49 AM
Has Anyone had their Wrangler Rewired Completely? jlangs Audio, CB & Ham Radios, GPS, & Electrical 5 08-19-2008 10:05 AM
I'm completely clueless somewherre Tires & Wheels 6 02-24-2007 06:37 PM
