Can I throw 35x12.5R15 BFG ATs on an 8" wide rim? - JeepForum.com
post #1 of 9 Old 04-05-2014, 10:28 AM Thread Starter
NWilhelm
The title is pretty much my question. My 99 TJ is being given to my father and he's dead set on not getting another set of mud tires. I figure a set of BFG ATs would suffice, however I've heard that BFG doesn't recommend their tires on rims less than 8.5" wide. Is this true?
: Black Hard Top/Strapless Bikini/Viking Fast Back Top | Warn Rock Crawler Front Bumper | Homemade Rear Bumper | Black Herculiner interior | Rokmen Rear Corner Guards |
NWilhelm is offline
post #2 of 9 Old 04-05-2014, 10:41 AM
biffgnar
biffgnar's Avatar
You will be fine
biffgnar is offline
post #3 of 9 Old 04-06-2014, 12:22 PM Thread Starter
NWilhelm
Awesome, thanks for the quick reply
NWilhelm is offline
post #4 of 9 Old 04-07-2014, 10:04 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Works great on a 8" wheel.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #5 of 9 Old 04-07-2014, 12:27 PM
4jeep44
yup, it will keep the bead good too
4jeep44 is offline
post #6 of 9 Old 04-11-2014, 10:09 PM
Ken Cooke
I have 35"x12.5r15s on 15x8" rims. My tires are chipping badly from all of my off road runs, making it difficult to balance these tires.
Ken Cooke is offline
post #7 of 9 Old 04-12-2014, 05:54 AM
Ed209
Have you gone to dynabeads or bb's?
Ed209 is offline
post #8 of 9 Old 04-12-2014, 10:48 AM
Ken Cooke
I haven't tried dynabeads. These might be a low-cost option allowing me to run the BFGs until I can buy a set of Falken MTs.
post #9 of 9 Old 04-20-2014, 02:36 PM
DRFlickner
Physically the tire can be mounted to the wheel and the bead will seat.
However, since the wheel is a little narrower for that tire and outside the approved rim width range of 8.5" - 11" the center of the tire will be slightly higher (domed) than it should be, which will likely result in accelerated wear vs. a rim width that falls within that 8.5" - 11" range. An approved rim width will stretch the tire properly across the rim giving it a more uniform fit.
You might get a ton of a mileage out of the tires and never notice a problem wight the 8" wide wheel and 35 x 12.50 x 15 tires, or you might get rapid wear in the center of the tire. It's something you'll have to keep an eye on. For the most part I think you'll probably be ok.
DRFlickner is offline
