Building the jeep...what's next? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Building the jeep...what's next?
All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to R
Unread 05-27-2006, 04:31 PM   #1
rpa0401
Ok so now that summer is here and I'm out of school for a while I picked up a second job to afford jeep stuff. So far I have got my 33's and the RE 4.5 SF kit is going on. I'm not sure what I should be looking to do next...It's my 98 tj which is my daily driver but I want it to be more than capable on the trails. Axles seem to be the next logical step but I'm not sure which axles would be the best to stick under there. I'm open to suggestions if anybody would like to give some input.
rpa0401 is offline   Reply With Quote
Unread 05-27-2006, 04:57 PM   #2
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
For 33's I would just go HP30 front from a XJ... For the rear I would do a Ford 8.8 from an exploder. Maybe some traction devices and 4.56 or 4.88 gears to go along with.
2013 FR-S
BlaineWasHere is offline   Reply With Quote
Unread 05-27-2006, 07:22 PM   #3
ps3tv
I must be missing something, because why would you go through the expense and work involved in an axle swap to end up with pretty much the same thing you already have? I'm not following this recommendation to swap from a TJ Dana 30 to an XJ Dana 30. I know, I know, low pinion vs high pinion, but so what, they're both Dana 30s.
If money is available for a significant upgrade go with a high pinion 9" front. If money is limited just put a lunch box locker in your front axle and re-gear it for the 33s.
The rear axle is more of a weak link than the front axle anyway, if you have the Dana 35. And if that is the case, I would recommend upgrading axles to anything but the Dana 35. First choice = Dana 60; second choice = 8.8; third choice = Dana 44.
2004 TJ Sport: Long arm suspension; Fox coilovers; Atlas II; Currie HP 9" front, & Rock Jock Dana 60 rear; Toyo 37s; Warn 9.5 XP
ps3tv is offline   Reply With Quote
Unread 05-27-2006, 10:55 PM   #4
BlaineWasHere
BecauseRacecar
HP30 = easy to get, cheap, and a direct swap for a TJ.
2013 FR-S
Unread 05-28-2006, 06:25 AM   #5
JeepJohnson
Yes, but he already has a D30 which is plenty for 33s. It's the rear you have to worry about if it's the D35. If not then your fine with that too. What are the specs on your Jeep, engine, tranny, gears?
Low Output 2.5L Member #39
Originally Posted by phaldor View Post
The top is a Barkertop...
Originally Posted by Capeman29 View Post
OH WOW, it electrically smashes all the fabric and windows together and looks like a big burnt marshmallow hangin off the back of your rig!!!!
JeepJohnson is offline   Reply With Quote
Unread 05-28-2006, 07:28 AM   #6
rpa0401
I have the 4.0 with manual tranny. Its got the 30/35 setup and stock gears.
Unread 05-29-2006, 08:53 PM   #7
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I agree. IN fact, it sounds like you probably don't wheel real hard. So keep the stock axles for now. I ran mine for 2 years with lockers on 33s. Went through the Rubicon twice. I never broke anything. You probably won't either.
And leave your front axle alone. My goodness...
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Unread 05-31-2006, 02:33 PM   #8
cb19950
aussie locker in front ummm 8.8 rear the shell out chash for a regear....but thats just what i would do if i had any money at all after a lift
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline   Reply With Quote
Unread 05-31-2006, 06:28 PM   #9
grandman97
if your planning on going bigger than 35s u might as well throw D44s F&R
grandman97 is offline   Reply With Quote
Unread 06-01-2006, 08:28 PM   #10
rpa0401
Thanks for the input...I was considering keeping what I have for now but I was told by the local shop I shouldn't lock them with 33's. I don't plan on running 35's because I hardly ever get a chance to go wheeling but hopefully that will change in the near future. My plan is to build everything up as strong as I can for now so I can avoid breaking things later when I don't have any money which would screw me pretty good since its my DD.
Unread 06-01-2006, 09:26 PM   #11
strokinout
Well, it all depends on how big you want to go and what kind of wheeling you want to do with it. State that info and we'll try to help you from there with a better understanding on where you want to go and where you're comin' from.
Ever sneezed with Copenhagen in?
Now looking for a another Jeep soon
In memory of:
1997 Jeep Wrangler 6-cyl.
1994 Jeep Wrangler 4-cyl.
strokinout is offline   Reply With Quote
Unread 06-03-2006, 11:49 PM   #12
rpa0401
Well for now just stickin with the 33's and superflex...only other plans for goin bigger in the near future are a BL and MML (maybe). When I do get a chance to get off road it's usually trails with lots of mud and just of little bit of rocks. I would like to get at the rocks a little more but like I said I just can't afford to start breaking things yet because I'm the typical broke college kid. Down the road I'm sure I will want to go bigger but only 35's probably (and a long arm kit ) I really appreciate the help fellas
