building for 40s... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > building for 40s...
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJeep Gear & Install Packages!Rough Country Lift Kits and Parts!
Unread 10-09-2014, 05:36 PM   #1
poptarts
building for 40s...
ok so I'm putting on some dana 60s, detroit lockers, 5.13 gears. i will be 3 link up front and 4 link in the rear. also doing hydro assist.
I'm building my jeep to be street able and also a rock king. lol
I'm in a 2002 tj with the 4.0 inline 6 with the automatic transmission. what tires should i go with? 39.5 iroks? 40 inch toyos? 40 inch mud grappler?
if you have 40s please post some pics.
2002 Jeep Wrangler APEX EDITION
!~FULL BUILD IN PROGRESS~!
poptarts is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 06:39 PM   #2
KKiowaTJ
That will be my next step, Just need the tires and axles. I have one axle but still looking for a front I like.
For the coin you are about to drop, Plus you want to DD it, Id look into the toyo's or kevlars. They will net you the look, Decent ride for DD and last a bit longer than others. 40" maxxis trep's don't look too bad either for a DD.
The grappler on a TJ in that size DD, Will bounce and lug slap like a bogger, Or my opinion when I rode in one. They are great on a jeep though and last, But better suited for a truck.
I built this guy a few years ago, 60 front/sterling rear, Too much of everything! Has copperhead fab beadlocks and 40" ground hawg's. I DD it, But it was a little too much all around.
YJ, TJ, XJ, ZJ..... Too many Jeeps!
KKiowaTJ is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 07:22 PM   #3
jason m
your ad here...
jason m's Avatar
Skip the 60 rear and get a 14 bolt or at least a Dana 70. Start with an axle that has 1.5" plus shafts factory.
That said I love my Iroks, the seem to flex well but the sidewalls don't pinch and cut. I run bead locks so my tires see pressures around 2-3 psi. The work very well in dry and wet rock. I would get them in 17" flavor, this way if a set of red labels come your way you are not buying new rims.
Oh and a pic of my tire kinda flexing,
That's a 39" irok smushed down till the tire hit the inner rim, I lifted that rock close to a foot off the other rock. Oh and that's when I ran a 14 bolt rear, ya that's why they are such great axles to it came out of that without any issues. And you should have seen how bound up I was, ask a dana 60 rear with 30 spline shafts if it can do that, you wont like the answer, LOL.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 10:13 PM   #4
poptarts
lol well its not my daily driver. i have a 2009 duramax with mud grapplers on it and love them. i think I'm getting a 14 bolt rear or dana 70. i think the set he is getting me is out of a 2006 f250. i did want a matching set.
ya i think its a toss now between the irok or mud grappler. i wish the pit bull rockers weren't so expensive. also what is a good street able beadlock?
Unread 10-09-2014, 10:31 PM   #5
jason m
your ad here...
jason m's Avatar
I would into the KMC rims for a better looking and more street friendly bead lock. The weld on kits you cant ever balance but perfect for a guy like me cause they are cheap.
If both axle are coming out of a 06 then it will be a 10.5 steerling rear with a metric pattern.
The after market world has caught up to the 10.5 and the 10.25 axle, beffy axles but im a 14 bolt guy. The only reason I run a 60 rear is cause its a steering 60 front chevy, if not I would have stayed with my trusty 14 b.
Jason.
Unread 10-10-2014, 05:11 AM   #6
CJ7nvrstk
Though the Iroks are phenomenal off road, I hated then on road. Sudden unexpected lane changes caused by your tires are not fun at 60 mph in traffic! They grip great, but that comes at a cost as well. Fast wear! My Iroks didn't last for crap, barely 20k miles. Btw, I was running the bias, radials I'm sure handled better on road.
RED Friday. Remember Everyone Deployed
CJ7nvrstk is online now   Reply With Quote Quick reply to this message
Unread 10-11-2014, 04:25 PM   #7
poptarts
ya ill be running a radial for sure.
Unread 10-17-2014, 04:32 PM   #8
bgredjeep
1987 YJ Wrangler
If I was looking for a streetable 40" tire, I'd get the Nitto Trail Grappler MT. I considered them for my Jeep, but since it doesn't see the road any more I went with comp trepadors instead.
bgredjeep is online now   Reply With Quote Quick reply to this message
