buggy lift - JeepForum.com
post #1 of 4 Old 11-10-2001, 01:26 AM Thread Starter
Rcklimr
buggy lift
anyone ever done a buggy lift front or rear on a yj? if so what are the pro's and con's?
90 yj 7" lift,35x12.5 mtr's,warn9000xd,atlas 2 4.3:1 t-case,4.11,kick a$$ stereo system, soon to have a buggy system front ??rear?? and an SRS
Rcklimr is offline
post #2 of 4 Old 11-10-2001, 06:50 PM
osburn
osburn's Avatar
Same thing as a 1/4 elliptical right? At least around here it means the same thing. Here's a very good article on 1/4 elliptical suspensions. http://www.jeepaholics.com/tech/quarterellip/
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 11-10-2001, 08:23 PM Thread Starter
Rcklimr
I dont think that they are exactly the same thing. It looks like in a 1/4 eliptical you don't have the regular leaf springs attached to the axle(like stock) they are hooked one eye to the axle and the other to the frame. on a buggy you have the leaves(like stock) mounted to the axle and then you would add a half of a main eye spring (so that you only have one eye) to the frame(using bolts) and then the shackle goes from the "buggy spring" to the axle leaf pack? don't know if that makes sense or not? Good article though. thanks.
Rcklimr is offline
post #4 of 4 Old 11-10-2001, 11:47 PM
osburn
osburn's Avatar
Ok, that's called 3/4 elliptical. You might try M.O.R.E. I know they used to have a kit. I don't know if they still do. I think Revolvers are a better way of achieving the same thing. You might email the fellow on the article I gave you the url to. I know he used to run a 3/4 elliptical a long time ago.
Matt Osburn
Score 1032
osburn is offline
my buggy build jason m Fabrication Shop 33 07-28-2009 09:49 PM
Homemade buggy xtreampyro General Jeep & Off-Road Equipment 3 04-21-2009 06:01 PM
fsj buggy 95% done welchct Fabrication Shop 5 01-16-2007 09:00 PM
my buggy welchct Fabrication Shop 2 12-18-2006 10:37 AM
Buggy Springs MiniTuckin Tires & Wheels 1 02-27-2003 12:45 PM
