Brake shoes in constant contact with drum - JeepForum.com
post #1 of 5 Old 06-26-2013, 04:07 PM Thread Starter
Haas2745
1993 XJ Cherokee
Could this problem be solved by replacing the wheel cylinder? I just recently replaced the shoes and my left side is having this problem. It seems the cylinder is seized up a bit.
Haas2745 is offline
post #2 of 5 Old 06-26-2013, 05:05 PM
mschi772
1997 XJ Cherokee
Did you back the adjuster off at all when you changed the shoes? If you installed new shoes, and the adjuster is still set for your old, worn shoes, that would explain it.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #3 of 5 Old 06-27-2013, 01:32 PM Thread Starter
Haas2745
1993 XJ Cherokee
After thoroughly looking it over I found out that it was a seized up ebrake cable, so I just cut it and that solved my problem 100 percent, I don't use the emergency brake anyways
Haas2745 is offline
post #4 of 5 Old 06-27-2013, 04:41 PM
mschi772
1997 XJ Cherokee
You'll feel differently on the day that you DO need it. I recently had a brake line bust while driving, and had my parking/e-brake been cut, I'd probably be dead right now. Willing to risk your life over a little laziness regarding a cable?
mschi772 is offline
post #5 of 5 Old 06-28-2013, 09:52 AM Thread Starter
Haas2745
1993 XJ Cherokee
It was seized up on the right side, so I atleast still have the left side
Haas2745 is offline
