brake fluid on tires??? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > brake fluid on tires???
Poison Spyder from CCOR!8.8 Swap Kit w/ TRUSS for JeepsDana 30 Truss for your TJ, LJ, ZJ, and XJ
Unread 03-12-2010, 10:24 AM   #1
supniceyeah
i changed the front calipers on my moms grand cherokee the other day and once i had the brake line off of the old caliper i wanted to quickly put it on the new one with out running the master cylinder dry so i put the old one down right next to me which happened to be on the tire i had laying next to the jeep...
when i was putting the tires back on i saw there was brake fluid from the old caliper on the side wall of the tire, but it was now dark out and i just wanted to be done so i was like forget it, i'll clean it tomorrow morning. morning came and i forgot, and i didnt get around to cleaning it off till the morning after, a day and a half after the brake fluid got on the tire... there is now a semi-noticable stain where the fluid was
long story short, will this cause major damage to the tire, to the point where it is unsafe to drive? i have heard of people using brake fluid as tire dressing back in the day before, not that i would ever do this but since people use to actually use it as dressing, then a little spill that i cleaned off two days later shouldn't do damage, right?
follow your bliss
1993 Jeep Grand Cherokee, 4.0 liter 5.5" lift, 32x11.5 mud terrains, black steel pro comps, 231 tc, 3.73 gearing
1996 Jeep Grand Cherokee, 4.0 liter, 242 tc, stock
1987 Jeep Wrangler, 4.2 liter, stock
supniceyeah is offline   Reply With Quote
Unread 03-12-2010, 10:25 AM   #2
supniceyeah
also, may not be the right section for this post, if not sorry, about that!
follow your bliss
Unread 03-14-2010, 05:59 PM   #3
supniceyeah
bump??
10 char
follow your bliss
Unread 03-15-2010, 09:19 AM   #4
+Crusader+
Did they recently quit selling keyboards with a 'Shift' and/or 'Caps Lock' key?
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller
+Crusader+ is offline   Reply With Quote
Unread 03-15-2010, 09:21 AM   #5
biggn235
I've never heard of brake fluid doing damage to a tire, I think you will be fine.
'98 XJ Sport
Build Thread
'99 XJ Sport
Build Thread
'95 YJ Rio Grande
Build Thread
biggn235 is offline   Reply With Quote
