Quantcast biggest tire size for stock 01 Wrangler - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > biggest tire size for stock 01 Wrangler
Poison Spyder BFH Rear BumpersFront and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yo
Old 11-12-2004, 01:43 PM   #1
mka428
Hi.
I have an 01 Wrangler Anniversary Edition.
What would be the biggest and best looking tire I can put on? Any suggestions?
I am looking for a very aggressive look, but something not too noisey.
Not wanting to put a lift kit on due to it being my daily driver and having 2 kids.
If anyone has pics, it would help a great deal.
Thanks.
Matt
mka428 is offline   Reply With Quote
Old 11-12-2004, 01:46 PM   #2
Coils Rule
There is a feature on this site called "search" try it!!
30 iches just so uyou don't have to this time 31's will rub but fit.
Coils Rule is offline   Reply With Quote
Old 11-12-2004, 01:50 PM   #3
PM Thor
Super Duper Guy
PM Thor's Avatar
Location: Banging your head against a wall uses 150 calories an hour
ehhhh, I have 31s on my stock 04, I don't know what the difference would be from an 01, but they don't rub at all, ever.
PM Thor is offline   Reply With Quote
Old 11-12-2004, 01:54 PM   #4
BigJeepJay
Disconnect...They will rub at full flex
Pics...
[URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL]
TJ Stretch Thread...
[URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL]
BigJeepJay is offline   Reply With Quote
Old 11-12-2004, 02:03 PM   #5
Coils Rule
Disconnect your sway bar. Only thing that runs 31 stock that won't rub in the TJ line up is the Rubicon.
Old 11-12-2004, 02:27 PM   #6
WarchildGT
I had 31's on my 2003 for 30,000 miles. Didn't rub once. Not sure what the diff is between the 01 and the 03 though...
-GT
WarchildGT is offline   Reply With Quote
Old 11-12-2004, 04:10 PM   #7
mka428
thanks
thanks .
any ideas in a manufacturer as far as an aggressive tire tread.
Old 11-12-2004, 04:11 PM   #8
Houston Terrell
hmm..
Buddy has 01 jeep wrangler with 33s... no lift or anything.. he had to take off his bumperetts tho. It dont rub unless he is offroad... but driving around town it dont rub at all...
Houston Terrell is offline   Reply With Quote
Old 11-12-2004, 05:01 PM   #9
Coils Rule
Originally Posted by mka428
thanks .
Goodyear MT/R's bro the best all around tire the world has ever known.
Old 11-12-2004, 05:44 PM   #10
KRAMONUT
thanks .
I like my 31" TrXus, good on & off road. Good tire for the price.
Each jeep is different & you CAN NOT say definitively that you will rub when disconnected. I had mine at max flex with no rubbing, granted my flares are a little wider (Rubi Flares), I didn't even have to adjust my steering stops at stock height or w/ a 1" body lift.
The only reason I even added the body lift after putting the 31's on was to get the gas tank up higher when I put on a raised skid & also facilitate installing a 'flat' skid in the future.
Sorry I don't really have any recent flex pics....but here's a couple of just the tires:
Finally painted my cage:
KRAMONUT is offline   Reply With Quote
Old 11-12-2004, 05:44 PM   #11
lupinsea
The MT/Rs are good but I hear they don't wear as long as the BFG's. And they're geared more toward rock climbing rather than mud but they have an impressive tread pattern.
BFG AT would be a good selection if you do a lot of road driving with some off-roading. The wear 40,000+ miles and do very well in snow. Tend to get packed up with mud but can handle off-road driving.
BFG MT are a great general purpose off-road tire. Lots of grip in muck and dirt trail conditions, they do ok in the rocks and wear a long time, too. Better for mud conditions than the MT/R's
Everything else is a toss up for wear, price, tread pattern, etc. There are Procomp MT's that are similar the BFG MT's and so forth. You can get just about any tread pattern from the different manufacturers.
I would recommend the 31" BFG AT's if this is going to be your daily driver. If you aren't afraid of a mild 2" budget boost lift (~$200 and it rides well) you can fit 32x11.50 tires. Something to keep in mind.
- Jay
lupinsea is offline   Reply With Quote
Old 11-19-2004, 08:39 PM   #12
I FLEX
I have a bone stock 01 with 31's when disconnected and flexing really hard i slightly rub.
I FLEX is offline   Reply With Quote
Old 11-20-2004, 03:28 AM   #13
juniork
I have a set of Cooper Discover S/T's they are aggressive, good in snow and mud, are not to noisey. I have 15,000 miles on them and they have wore just a small amount. Check them out.
http://www.coopertires.com/us/en/ProductDetails.asp?ProdType=LtTruck&id=190&title=L ight+Truck+Tires
2003 Jeep Wrangler X, Freedom Edition, Patriot Blue Metallic. Dana 44 Trac-Loc rear differential, 3" Suspension lift, Transfer Case drop kit, Cragar soft 8's with 33x12.5 Kumho's, HF 8000 lb Winch.
1969 Dodge Coronet R/T, 360 crate motor with edelbrock heads, auto tranny
juniork is offline   Reply With Quote
Old 11-27-2004, 10:15 AM   #14
Rubie Tuesday
I ran 31.5's on mine before it had a lift (97 sport). It rubbed up front but it still ran fine. You just won't be able to make tight turns without a little bit of rubbing. It looked bad ***, but then I got a 4 inch lift- then it looked like a roller skate ...
Rubie Tuesday is offline   Reply With Quote
Old 11-27-2004, 10:17 AM   #15
Rubie Tuesday
o yea, forgot to mention- they were brand new goodyear AT/S. nice tire!
Glock Forum
