Quantcast Bias Ply vs Radial Tires - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Bias Ply vs Radial Tires
Old 10-26-2004, 04:37 PM   #1
Inukshuk
I am going to change my tires for 32" x 11.5". I will be doing extreme off-road about 6 times a year the rest of the time on gravel and seven months of winter. My choice of tires are the TSL-SX bias or the TSL-SSR radial. Both are 6 ply. I'm told that the rubber compound of the SSR is harder, but that the radial would give a more comfortable ride. With this how would that SSR be off-road? and it's side walls would they be okay?
I'm ready to order now, but would like some extra input.
I'll be using standard rim off-set 8" wide and just adjust the little nut so I don't get any rubbing.
http://inukshuk.smugmug.com
I just love to go where no man has gone before.
Rock climbing, in marshes, atv trails, mud, tundra etc.
Inukshuk is offline   Reply With Quote
Old 10-26-2004, 06:23 PM   #2
YJ_Aaron
I posted on your other thread. You should probably delete one or the other
YJ_Aaron is offline   Reply With Quote
Old 10-27-2004, 01:34 AM   #3
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Radials are better for the road. If these won't see pavement to often, then I say go with the bias ply. I am currently running bias ply tires and they are great on the trail, especially when aired down. I can't say the same for the road though. They vibrate, they rumble, they kill my gas milage, and they get cold spots Once I get my new set of rims, I'll be using radials on road, and these bias for trail use only.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Glock Forum
