BFG rugged terrain tires.. tread is coming off on all 4 tires.... - JeepForum.com
post #1 of 7 Old 04-08-2014, 08:12 PM Thread Starter
Candymancan
I have newer rugged terrain T/A on my 5.9, I have had em for only 1 year and 1 month.. they have 18k miles on em.. when I was doing my brakes today I noticed all 4 of my tires inside and outside have a solid crack line on the top of the tire on the sidewall by the tread going the entire circumference of the tire... The tread is starting to peel off the tires..... I went to a mechanic to have it looked at and he said yes the tread is peeling off and it can be very dangerous for my vehicle and myself if it comes off..
He told me his shop can call BFG and get replacements under warrenty but BFG might only cover like 70% of the cost.... I think that is BS... Has anyone ever had had BFG tires do this ?? Should they replace all 4 tires at no cost... I mean if all 4 are separating then something is wrong with the brand of tire...
Candymancan is offline
post #2 of 7 Old 04-09-2014, 04:12 PM
11B-33T
Can you take them back to the tire store you got them at? You should be able to get replacements at a pro-rated cost but you'll come outta pocket some.
11B-33T
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
- 2003.5 Mazdaspeed Protege
11B-33T is offline
post #3 of 7 Old 04-09-2014, 05:55 PM Thread Starter
Candymancan
Yea I took them in an the place measured my tread depth.. I showed the 4 recipts I had from the alingments I did and the original when I got them a year ago.. they will call me back tomorrow they said.. Michelin wanted to know which tires I wanted as a replacement I said A/T's if they are the same price but ill stick with the T/A's if I have too.. but if im paying 30-40% out of pocket then they can go to hell
post #4 of 7 Old 04-14-2014, 05:51 AM
WXman
Why? Did you not use 30-40% of the tread life? Why would they give you 100% refund for tires that are only 70% tread? Shouldn't have purchased tires from a French company to start with. Over-priced over-rated trash tires. Get you some Coopers or Generals.
Sent from AutoGuide.com Free App
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #5 of 7 Old 04-14-2014, 08:19 AM
wilson1010
Delamination of the tread outside of the cord layer is a fairly common problem caused by contamination in the factory, usually smoke from overheated equipment or a plant shutdown. It makes for a very dangerous situation.
BFG will be very interested in the build date and lot or serial numbers of the tires and you should hold out for a 100% replacement. Threaten to go to the NHTSA if you don't get 100%.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #6 of 7 Old 04-22-2014, 09:19 PM Thread Starter
Candymancan
They only offerd me a 20% discount on new tires... yet I have 70% of my tread life left.. according to the shop and them... lawl.. w/e ill just keep my tires if they blow up and dmg my vehicle they are paying for it.
post #7 of 7 Old 04-27-2014, 02:45 AM
rdbs505
I'd go with wilson's advice, this seems sketchy.
rdbs505 is offline
