BEST way to balance a large tire - JeepForum.com
post #1 of 14 Old 04-24-2009, 01:00 PM Thread Starter
Imped
Imped's Avatar
Hey guys, I've got 35" KM2s that Discount Tire can't seem to balance. I've been back more than 5 times and sometimes it gets better, sometimes no better at all. Sometimes they go toward the weight strip on the inside of the rim method and sometimes they use pound-on weights. I've continually got a tire wobble at 50+mph up front. I've narrowed it down to the tires. What should I tell them to do this next time? I need these things BALANCED.
OlllllllO
IndyORV
Imped is offline
post #2 of 14 Old 04-24-2009, 03:43 PM
GilaMtnJeep
GilaMtnJeep's Avatar
They may need to be shaved.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 14 Old 04-25-2009, 12:07 AM
chainz
1976 CJ5
I have found from some people that mudders are sometimes not very round to begin with but sometimes they can slide the tire around on the rim to better balance it I have found that the only reliable way to balance a tire is with the pound on wieghts.Maybe in the end you will just have to have them put the best balanced tires on the front and live with a little shaky shaky
chainz is offline
post #4 of 14 Old 04-25-2009, 01:56 AM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
Having them put all the weights on the inside by chance? That won't correct for a dynamic inbalance.
How did you narrow it down to the tires?
Live in SE WI? ----->
Jesse-James is offline
post #5 of 14 Old 04-25-2009, 06:51 AM
Schmidthappens2
I have BFG 33X10.5 A/T and have had the same problem. The discount tire places donít know how to balance properly. You need to take them to a 4X4 or off road specialty place. I take mine to sears and they balance them perfectly. The main reason is this: a normal balancing machine is not made for a 35" tire. Try calling around other places and see if you can find a place that does Road Force Balancing. Basically they find the high spot in your tire and match it up to the low spot in your rim. This makes the whole thing as cylindrical as possible. Check the amount of weight they used to balance your tires...if there's not at least 3 oz of weight being used your paying for nothing and might as well leave the tires with no weight. If you feel like experimenting you can try balancing beads.
Schmidthappens2 is offline
post #6 of 14 Old 04-26-2009, 01:14 AM
KKiowaTJ
Go to 4wheelparts in Indy on E. Washington i think? They balanced my set Krawlers for $60. I haven't knocked one off, Had any vibes, All on the inside where it can be seen. Guys name is brinks, Gave me a good enough deal i drove 5 hour one way. Good luck
MOPAR!
KKiowaTJ is offline
post #7 of 14 Old 04-26-2009, 03:38 AM
JaikYJ
Have you looked into beads? I am tryin them out right now, I have noticed that they seem to work alittle bit better. I dont know if I am 100 percent convinced yet though. But some guys swear by them.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #8 of 14 Old 04-26-2009, 03:05 PM
jeepin1995
jeepin1995's Avatar
i recently got a set of 36" bias iroks on cheap steel wheels..... i mounted them myself with a big prybar and poured 12oz of copper BB's in each tire...... they roll smoooooooth..... i was skeptical at first, but i'm a believer now!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #9 of 14 Old 04-26-2009, 03:28 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Find a Discount Tire store that has a Road Force tire balancing machine, not all do and that's the only balancing machine that will always get my 35" tires balanced perfectly. If my local Discount Tire store didn't use the Road Force machine as I always request they do, I always have to come back and then I INSIST they use the Road Force machine and then I watch to make sure they do. It takes more time and skill to run so they don't normally use it if they can avoid it.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #10 of 14 Old 04-26-2009, 06:41 PM
blackattak
Took the BFG ATs off on Friday & put on new Mickey MTZs on MT Classic II wheels. Before when I was on the highway no shake in the steering wheel, now when I hit 55 mph you can feel a shake in the steering wheel. It is not extreme but figure if it is going thru the steering wheel (& I have a steering stabilizer) that it is likely the new tires NOT BEING BALANCED as well as they could be. Would that be the likely culprit. Do I just need to take it back & get them to check the balancing again (shake can't be the best thing for tire wear I presume).
2004 LJ- 33X12.5 Mickey MTZs, Mickey Classic II wheels, 4.88 Yukon Gears, 3" BDS SL, Rockhard Rear Bumper with Tire Carrier & Rockers. Oil Pan, Warn Gas Tank Skid. & Differentials armoured, Iggee Seat Covers, Warn M8000 winch.AEV TT & tranny skid, radiator & steering box skids
blackattak is offline
post #11 of 14 Old 04-28-2009, 01:43 PM
Jerry Bransford
Administrator
That's purely a tire balance issue. Of course you should take it back and tell them to re-balance them... but to get it right this time.
Getting
post #12 of 14 Old 04-28-2009, 05:56 PM
blackattak
Thanks Jerry.
Figured that's all it was. I'm not sure they even balanced them (they were busy & it may hove been missed) as there does not appear to be any weights added to any of the wheels from what I can see. Sent them an email letting them know last night but have not heard back yet (they often take 48 hrs to reply). Overall I have been very pleased with hese guys & we all can make mistakes.
post #13 of 14 Old 04-28-2009, 06:50 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I've got beads in my Durango, beads in my Mercedes, beads in my son's Honda. I had beads in my Jeep until the slow air flow airing down got too annoying (yes, I used the special valve cores). When I added Trxus tires a few yrs ago I just didn't balance them at all. I cut two of them over time and bought two more, so that's 7 of them not needing balancing at all. If they did, I'd try the bb's, since they wouldn't cause the slow air down.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #14 of 14 Old 04-28-2009, 07:22 PM
blackattak
Apparently my shop "static balanced" my wheels & now say that it looks like they need to be `dynamic balanced`& that they`ll do that for me. Not sure what the difference is… As long as my shake at 55 goes away I don`t care.
tire balance khill8469 Tires & Wheels 1 10-30-2009 12:24 AM
Tire Balance CJ-TJ Tires & Wheels 0 07-09-2008 10:02 AM
Tire balance grnsporty Tires & Wheels 4 12-10-2007 03:12 PM
Tire mount and balance.... ragweed13 Tires & Wheels 3 03-23-2006 09:44 PM
Tire Balance ?? Metal Tires & Wheels 9 11-26-2005 10:47 PM
