best 1" body lift kit.. - JeepForum.com
post #1 of 4 Old 10-27-2001, 07:11 PM Thread Starter
evilpsych
evilpsych's Avatar
k guys.. what's the best 1" body lift kit or 1-1 1/2" susp. lift.. i only wanna run 31's
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 4 Old 10-27-2001, 07:29 PM Thread Starter
evilpsych
evilpsych's Avatar
oh.. umm is there a good walkthrough on what else you ahve to change to get everything working correctly after a 1" body lift? like the pedals, shifters, steering column, etc..
A
post #3 of 4 Old 10-29-2001, 06:40 PM
osburn
osburn's Avatar
The "best" is the Daystar. It doesn't just stack pucks on your existing body mounts, it replaces them with 1" taller body mounts. Plus, if you've ever seen the cheesy spacers they put under both sides of the grill in the front, you're gonna want the Daystar when you see it done right. Daystar runs about twice as much though. The only thing I had to do was trim my fan shroud a little. No other effect from a 1" body lift.
Matt Osburn
Score 1032
osburn is offline
post #4 of 4 Old 11-10-2001, 01:45 PM
Lukasz
and what do uou think about M.O.R.E body lift system ??
: 329RRv1.0
Lukasz is offline
1.25" Body lift on top of 2" coil spacer lift? 79SilverCJ Tires & Wheels 4 01-08-2007 05:38 PM
Currie TJ 1" Body Lift vs. JKS 1.25" Body Lift MaverickTJ Tires & Wheels 7 03-10-2006 02:07 PM
2.5" sping lift w/3/4" spacer and 1" body lift... Mus35th Tires & Wheels 3 08-30-2005 07:50 PM
Does 2" OME lift + 1" Body/MM lift = No TCase Drop? Black 2001 TJ Tires & Wheels 4 10-24-2002 07:57 AM
2" Body Lift and 2" Coil Spring Lift Together a good idea?? YellowSE200 Tires & Wheels 1 01-09-2002 07:43 AM
