Quantcast beads to balance tires - Page 6 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > beads to balance tires
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-11-2009, 04:51 PM   #76
pendleton
why not just get beads made for the application..dynabeads
Cost. Airsoft bead are half the cost and seem to do the same thing.
My Jeep: 2002 RED Wranger 'X'
pendleton is offline   Reply With Quote
Old 08-14-2009, 08:04 AM   #77
Buff60Indian
I didn’t read the entire thread but I had them installed on my ProComp All Terrain 32x1150 and my buddy had them installed in his 33x1250’s and we had a terrible experience with them. They would ride smooth but induce a serious death wobble at about 40 – 45 mph. Both of us had the shop replace them for standard lead at the shops cost. I do hear good things about them for 35’s and up though.
Buff60Indian is offline   Reply With Quote
Old 09-06-2009, 08:28 AM   #78
BobbyG750
Im going to try the AirSoft BBs...the heavy ones (.20grams). Got the diet scale and BB's at walmart. $10 bucks for the scale, $11 for each container of BB's. Im trying 14oz per tire in 16/40-17 LTBs on Allied's.
BobbyG750 is offline   Reply With Quote
Old 09-20-2009, 11:30 PM   #79
kubwa_jim
I used the .20 gram airsoft pellets to balance my 42in TSL's. Worked like a champ, never clumped, tires ran straight and smooth at any speed. I'm about to do it with my 33's.
Don't look at me, your rights were violated before I ever got here!!
kubwa_jim is offline   Reply With Quote
Old 02-17-2010, 04:37 AM   #80
ClimbStuff
I bought some of the .12 gram beads today... going to try 8oz in each of my new Duratracs... See what happens *Fingers Crossed*
ClimbStuff is offline   Reply With Quote
Old 02-17-2010, 10:49 AM   #81
sheer
I know guys that use old golf balls and swear by them....just in case anyone wants to try.
sheer is offline   Reply With Quote
Old 02-18-2010, 05:33 PM   #82
mdywglr4x4
Traded some tires today and the guy was going to throw some into the 36" Iroks. Was running them with standard weights and all was good before.
Running 35s now that are radials. Will have to see how it goes when I pick it up here in an hour.
*2000 TJ* - Long Arms - Big Tires - Chrome Shafts - Locked and loaded + Body Armor
*1988 325iS* - Coils - 24v Swap - Sways - Road Warrior
mdywglr4x4 is offline   Reply With Quote
Old 02-18-2010, 05:48 PM   #83
ClimbStuff
I got my 33's with 8oz+1/3cup (had some extra) of the .12gram air soft beads... they balanced very nicely! I feel some wobble now from about 38-45, but its manageable. No bouncing at freeway speed either. I think the BB's would work better because you can place more mass in one spot than with the larger air soft beads.
Old 02-19-2010, 12:50 PM   #84
Ross
Originally Posted by Lager View Post
To you guys who have used them, can you hear any sound from the beads or BB's? I have my top down most of the time, so I would like to know if there is any noise that you can hear.
I have 10oz of steel bbs in my 33 TrXus and I can only here them if I jack the tire up and spin them.
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more
"If you aim at nothing, you will hit it every time."
— Zig Ziglar
Ross is offline   Reply With Quote
Old 02-23-2010, 07:08 AM   #85
Rynoman27
This is amazing. When i get my new tires here soon i will definitly be doing this.
Rynoman27 is offline   Reply With Quote
Old 02-23-2010, 10:28 PM   #86
kubwa_jim
I've seen the inside of tires that used golf balls and they were TORE UP! It looked like someone had taken a grinder to the inside of the rubber.
Old 02-24-2010, 01:19 AM   #87
ClimbStuff
My tires go out of balance over 65mph... It works great for city streets and such, but trying to run 75 or 80mph just isn't happening. I'll be having them removed and balanced at the shop on Thrusday.
Old 02-24-2010, 07:53 AM   #88
Ross
You have another issue to look at. I get some wooble at about 55-60 with mine, seems that wobble at a certian speed is common to many using beeds or bbs to balance. If it is causing you death wobble need to find out why.
— Zig Ziglar
Old 02-24-2010, 04:45 PM   #89
sdowney717
curious how the beads affect getting you tires balanced at the shop.
If you have beads or antifreeze, whatever in there.
sdowney717 is offline   Reply With Quote
Old 02-24-2010, 05:49 PM   #90
flatlander757
Now in the 937
flatlander757's Avatar
Wheel and tire copycat
I don't know where you got the 14oz figure from, but that just happens to be exactly what I put in my own wheels. Since they're bias they will flatspot, but once warmed up I have no vibes or wobbles or anything. I have had some very minor shimmy around 45-47mph but it goes away pretty quickly and doesn't bother me. It also doesn't happen all the time, only occasionally. I have no steering stabilizer or anything attached for the time being. I think when I add hydro assist it won't even be noticable.
Video is only up to 45 or 50mph, but I've had it at a constant 70mph before with no issues.
FWIW I think 15oz might work slightly better.
I used the heaviest steel BBs I could get... I think they are zinc coated? My reasoning is that heavier BBs = less # of BBs required to get to the needed weight = less likely that multiple BBs will want to fight for the same spot in the tire.
I have no evidence to back it up, but I think that some people might have problems because if you use the super light BBs, it requires a HELLUVA LOT of them to equal 14oz or whatever. Centrifugal force dictates the tires go outwards on the sidewall inside the tire. If you have a "light" spot on the tire that is maybe 4" round or whatever, I'd rather have less BBs fighting for the same spot because they sure as heck aren't going to stack on top of each other, they're going to fight each other and some will end up where weight is not needed/wanted.
/my personal theory.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Glock Forum
