Quantcast beads to balance tires - Page 5 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > beads to balance tires
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 02-17-2009, 01:09 PM   #61
jcarr
I've seen liquid tire balancer for motorcycles but not for cars/truck tires.
jcarr is offline   Reply With Quote
Old 02-17-2009, 06:44 PM   #62
Eaallred
1962 CJ5
Hahaha. Laughing at myself.
Water will freeze. Big chunk o' ice in the tire in the winter months. Duuuuh.
But, there is liquid tire balancer:
http://www.deltatiresealant.com/tire_balancers.php
I bet RV antifreeze would work. Non-freezing, and has rust inhibitors so it would work on a steel rim. Plus, enviro-friendly if you lost a bead and 'spilt' some on the trail.
Maybe i'll try that instead.
Eaallred is offline   Reply With Quote
Old 02-17-2009, 11:19 PM   #63
ep191
Originally Posted by Eaallred View Post
The water couldn't evaporate anywhere. It will always stay in the tire. The amount of water that would evaporate and stay airborne would be very minimal/unmeasurable.
I bet it would work the same as beads. I'm getting new tires with my tax return, if I end up buying the Harbor Freight tire changer to do it (rather than take the tires in) I may try it.
It will be essentially free, only take some labor on my part to pop the bead and wipe out the water if it doesn't work. Maybe i'll mount the tires, drive it, and if there's a shimmy and a shake, i'll add 8oz of water and drive it again and see what it does. I'll report back if I do it, wether it works or not.
Yea i see what your saying but when the tire temp rises the water will turn into water vapor inside the tire and will not work the same way as liquid water will in balancing the tire.
Also after a lot of airing down on trails air is likely to burp out of the lip (water vapor will as well) Water by itself just seems like it would be too hard to regulate. Using some other type of liquid i assume would work, something that isn't so easily evaporated into the air. Also i can't imagine all that old nasty water sitting inside won't do the tire much good.
ep191 is offline   Reply With Quote
Old 02-22-2009, 05:32 AM   #64
Muddeprived
Water isn't a good idea. You know those little motors with unbalanced wheels on them in that they use our phones and....personal vibrators? That's what your jeep would be like x4 when it gets below 32.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 02-22-2009, 12:18 PM   #65
Eaallred
1962 CJ5
Been looking online on this, and have found anti-freeze has been put in tires for years now with great results.
Soon as I get my new tires on and running, i'll post the results of my own findings with it.
Old 04-08-2009, 05:00 PM   #66
BRad704
Nothing to see here...
BRad704's Avatar
anti-freeze is a pretty good idea! prally the same weights as with bb's or beads...
I'm just wondering how easy it is to re-seat a bead? I want to do this to try and balance out some old Interco thornbird 31x12.50's...
Originally Posted by Jungle Recon
*** this quote has been removed by BRad, in order to maintain the level of maturity that is required in an online forum of one's peers.
BRad704 is offline   Reply With Quote
Old 05-06-2009, 02:54 AM   #67
Jeepguy1977
Anyone had any luck getting a shop to put the Air soft pellets in for them during the mounting process?
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote
Old 05-06-2009, 06:47 AM   #68
sdowney717
just use antifreeze!!
remove the valve core.
squirt the water in using a syringe or rubber ear bulb ETC......
your done at almost no cost.
start with 5 ozs and then put in more if needed. IT will NOT evaporate in the tire.
no beads to buy, no shops to deal with. no damage to steel rims.
If some company packaged up some antifreeze with a syringe applicator and sold it as a "dynamic tire balancer" for 10$ a shot, people would buy it and be raving about it on the boards.
sdowney717 is offline   Reply With Quote
Old 05-06-2009, 09:49 AM   #69
twobit
A google search for "liquid balance tires" shows several products. I wonder if the tire manufacturers approve of liquid balancing?
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
twobit is offline   Reply With Quote
Old 08-10-2009, 12:08 PM   #70
reservoirdogg26
do you just pour em through the valve stem or do you put em in when mounting it on the rim
reservoirdogg26 is offline   Reply With Quote
Old 08-10-2009, 12:25 PM   #71
reservoirdogg26
about how many bb's is 8 ounces?
Old 08-10-2009, 12:32 PM   #72
ep191
the shop i went to had no problem with doing it, but a friend of mine also knew people there
depends on the shop for liability reasons most likely
I would imagine you can do the same with BB's by removing the valve core, it may take more time but you can do it.
I don't see where having shops to deal with is an issue, you still have to get them mounted somehow. You can deal with putting the BB's in later.
I also see BB's as a cheaper option than antifreeze. You can re-use BB's everytime you do a tire change. Good luck getting the shop who un-mounts your tires to want the hassle of dealing with the anti-freeze.
I put mine in while mounting the rim with one of the beads unseated. I'm sure you could do it either way though, it just may take longer.
I just weighed the whole jar out on a bathroom scale, and split them up from there just by guessing. It won't hurt to put in a little more than needed.
Old 08-10-2009, 01:19 PM   #73
BRad704
BRad704's Avatar
8 ounces is 227 grams.
The standard brass BB's (Crossman Copperhead's from W-mart) are 5.28 grains each. This is 0.342 grams each.
Then you are looking at 227g/0.342g or 664 BB's (give or take one for my rounding during calculation).
This also can be back calculated to say that a brass BB weighs approx 0.012 ounces.
Have fun with THAT one if you dont have a scale!!!
Old 08-11-2009, 03:25 PM   #74
pendleton
What happens with the steel BB's when you have a blow out going 70 MPH down the highway? I'm thinking of doing this, but would go with the airsoft media instead for this very reason.
My Jeep: 2002 RED Wranger 'X'
pendleton is offline   Reply With Quote
Old 08-11-2009, 03:46 PM   #75
2006_Sport
why not just get beads made for the application..dynabeads
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is online now   Reply With Quote
Glock Forum
