Quantcast beads to balance tires - Page 4 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > beads to balance tires
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 09-25-2008, 01:25 PM   #46
Terrain Twister
Terrain Twister's Avatar
I'm assuming everyone that is doing this has eliminated any other balancing weights on their wheels?
'04 Unlimited, Auto, I6
35x12.50R15 DC Mud Country's, Rock Krawler 4.0" X Factor Plus Short Arm System, OME shocks, Warn M8000, 4.88's and Home Brew Bumpers/Tire Carrier!
Tube Fenders being Built!
Terrain Twister is offline   Reply With Quote
Old 09-25-2008, 08:10 PM   #47
ep191
i dont think that would happen because in theory when you are driving the bbs quickly move to the spot they are supposed to go and centrifigual force keeps them in one spot. The tire is rotating so fast i would find it hard to believe that the bbs could move at all once the tire starts moving.
ep191 is offline   Reply With Quote
Old 09-25-2008, 08:12 PM   #48
ep191
^meant to put this quote in that post
Originally Posted by jdragger View Post
What about the steel BB's? Don't they bead blast the tire and the wheel, effectively wearing the tire from the inside out? The Dynabeads must have a finite life. Let us know how long these last. What about aluminum wheels and bb's or beads?
Old 09-25-2008, 08:21 PM   #49
Lager
Your correct, no other balancing is required. The beads work really well and I'm honestly suprised how well they work.
Lager is offline   Reply With Quote
Old 11-25-2008, 04:58 PM   #50
USMC_XJ
USMC_XJ's Avatar
1994 XJ Cherokee
BTT
how would airsoft BB's work if you tried to air down? wouldnt they get sucked and block the valve? just asking because looking to get sum 33 Trxus and heard they suck for balancing, so i thought id give the air soft bbs a try.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline   Reply With Quote
Old 11-25-2008, 07:44 PM   #51
Lager
I've never had any problems airing down and getting the bb's stuck.
The bb's I use came from Innovative Balancing and they also sell you special air vavles to keep the bb's in the tire. If your using different bb's then me, then maybe you could just get the air vavles from Innovative Balancing.
Old 11-26-2008, 08:35 AM   #52
NJHCx4xLIFE
Originally Posted by soldierp89 View Post
BTT
Air down with the valve stem at the top of the wheel... all the bbs will be sitting at the bottom of the tire.
NJHCx4xLIFE is offline   Reply With Quote
Old 11-26-2008, 11:48 AM   #53
06_LJCON
Any good tire shop should be able to balance any tire. Yes some are harder to balance then others and take more weight but I have yet to find a tire that I cant balance they might take me a few extra minutes but its worth it. If anyone has a radial tire that want more then 10oz of lead then they shouldn't be putting that tire on a daily drivin vehicle!!! I could totally see using that much or more for a bias ply but not a radial.
(SOLD) 1991 wrangler 2.5L 5-Speed White, 2" BL, Warn rear bumper, warn winch, warn rock sliders.
(SOLD) 1987 wrangler 2.5L 5-speed BLACK!
S.O.A. with 4" springs and a 2" body lift. Lincon locked front. 33" TSL's NEED bigger tires!!
(WRECKED) 2002 Apex Wrangler 4.0L 5-Speed Silver
2.5" skyjacker single flex, skyjacker shicks, Rock Krawler adjustable lower control arms f/r, 1.25" JKS body lift, 1" JKS motor mount lift, JKS Quicker Disconnects, Warn engine/transmission skid plate, Rock Crusher Front diff cover, Poison spyder rocker knockers, 1.25 wheel spacers, 4.10 gears f/r, Detroit Trutrack rear, aussie automatic locker front
(CURRENT) 2006 Wrangler Rubicon Unlimited LJ 4.0L 6-speep, Silver, 3.5" Rubicon express lift with Rubicon express disconnects. Hella 500 lights, HID Bi-xenon headlights, Rock-It intake, Red top Optima, Factory MOPAR rocker knockers, TNTCustoms Front full tube fenders, 35x12.5R15 BFG KM2, Black steel wheels.
06_LJCON is offline   Reply With Quote
Old 11-26-2008, 11:54 AM   #54
06_LJCON
OH also DO NOT put anything inside the tire if you have TPMS (tire pressure monitering systems)!!!! BB's will damage them eventually.
Old 11-26-2008, 12:47 PM   #55
mdm
Farm Wheeler
If you are running beads in your tires, fix-a-flat type flat fixers are a big no. This will cause the beads to clump and not move inside the tire properly. I had beads in my wife's tires until her uncle "fixed" a flat for her when she was visiting family up north. It caused a horrible shake.
If you pop a bead off-road in mud or water you will have to break down the tire and clean it out. You will later have to replace the beads unless you are somehow able to recover, clean, and dry them.
You will need to be careful what you use to air up your tires. An air source with water or oil can also cause the beads to clump.
I am using the Dyna Beads from Innovatve Balancing in 35x12.5 BFG KM2 tires. They work well, with a slight shimmy at around 45 mph. Take a look at their FAQ, How it Works, and Advice pages. There is a lot of good information to be found there.
http://www.innovativebalancing.com/news.htm
http://www.innovativebalancing.com/HowItWorks.htm
http://www.innovativebalancing.com/application.htm
When I have a wheel off I can hear the beads when I roll the tire but I never hear them when driving.
mdm is offline   Reply With Quote
Old 11-26-2008, 04:16 PM   #56
USMC_XJ
USMC_XJ's Avatar
1994 XJ Cherokee
makes sense. i was just worrying about that, but i will try the 8 oz of airsoft BB's. i have read somewhere that 8 oz is around 2,000 airsoft pellets. can anyone confirm this?
Old 02-15-2009, 10:55 PM   #57
Dad03
1975 CJ5
Would'nt lead bird shot work and fit through valve?
Dad03 is offline   Reply With Quote
Old 02-16-2009, 08:40 AM   #58
Eaallred
1962 CJ5
Hmmmmm.
Would 8 oz. of water work as well as 8 oz. of beads?
If you don't have steel rims, I can't see it causing any real damage.
Eaallred is offline   Reply With Quote
Old 02-16-2009, 09:47 PM   #59
ep191
Originally Posted by Eaallred View Post
Hmmmmm.
First of all like you said most people have steel rims so that isn't the best idea.
And I'm not an evaporation expert but i imagine 8oz of water to start, will not always be 8oz of water in the future. I'm sure water would work but it would take so much maintenance to work well.
Old 02-17-2009, 08:37 AM   #60
Eaallred
1962 CJ5
The water couldn't evaporate anywhere. It will always stay in the tire. The amount of water that would evaporate and stay airborne would be very minimal/unmeasurable.
I bet it would work the same as beads. I'm getting new tires with my tax return, if I end up buying the Harbor Freight tire changer to do it (rather than take the tires in) I may try it.
It will be essentially free, only take some labor on my part to pop the bead and wipe out the water if it doesn't work. Maybe i'll mount the tires, drive it, and if there's a shimmy and a shake, i'll add 8oz of water and drive it again and see what it does. I'll report back if I do it, wether it works or not.
Glock Forum
