Quantcast beads to balance tires - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > beads to balance tires
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 08-03-2006, 08:08 PM   #16
crawldit
Your reason number one is exactly why I used internal balancing on my 31's. I hated having to pay to get my tires rebalanced after every single wheeling trip. That got way too expensive.
2005 Rubicon :
4.0 Automatic,4.11 gears,4:1 Transfer Case
Teraflex 3" Coils,Rancho 9000x's,35" KM2's,(fenders...what fenders?), Cobra CB, Lowrance Baja 480c GPS,2"Wheel Spacers, Big Daddy Tie Rod,Superior Evolution Shafts.
crawldit is offline   Reply With Quote
Old 08-04-2006, 01:25 PM   #17
markc522
wow. so it really works. i have been having trouble balancing my 33" baja claws.
and when i get new tires, i think i will throw in some bb's to help keep them balanced. (the ware and therefore get out of balance)
how does beads keep things in balance?
wouldnt they just stick to the wall of the tire when spinning?
how much would i need for 33x1250's?
can too much or too little cause them to work improperly?
sorry for all the questions.
2003 wrangler x
somewhere around a 4" frakenlift -
33" claws - black soft 8's - dt8000's - disco's
yellow jeep club member #874
JEEP: 1 2 3 4 5 6 7 8 9 10
markc522 is offline   Reply With Quote
Old 08-05-2006, 04:20 AM   #18
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
to answer your first question, read your second question. thats exactly what they do. think back to when you were a kid at the beach and you would spin a bucket of water around in a circle. centrifugal force kept the water in the bucket. when your tires spin, centrifugal force will throw and spread the BBs out in the tire, they will naturally drift to the off spots and help keep the tire balanced at speed. (at least that is my understanding of how it works, but I am no engineer)
7 ounces works fine in my 35x12.50s. id try 6 ounces or so for your 33s. too few won't get the job done, i dont know if too much will have a negative effffect or not
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 08-05-2006, 04:20 AM   #19
92 Green YJ
Head Brewmaster
Old 08-05-2006, 04:37 AM   #20
TJ on the Rocks
in reply number 9 you said you have 8 ounces of BB's in your 35" tires
Do you know how many ounces of BB's you have in each tire or are you just guessing ?
Sorry bro , I'm new to the BB technique . Trying to alleviate breaking the bead and adding or subtracting if i don't have to ......... Frickin Interco tires
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation
[/COLOR][/SIZE][/CENTER]
[CENTER][B][/SIZE]
[SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE]
TJ on the Rocks is offline   Reply With Quote
Old 08-05-2006, 02:15 PM   #21
92 Green YJ
Head Brewmaster
let me try and straighten this out.
when I first did the BB balance (about a year and a half ago or so i think) I put 7 ounces of BBs in my 35x12.50 pro comp Xterrains wrapped around Steel American Racing AR 767s. it worked great.
Now about 6 months ago, I ordered and added on a DIY weld on steel beadlock kit from Great Lakes offroad. I was concerned that the added weight, and likely unevenly added weight at that due to weld variances and such, would throw the balance off. So I added an additional ounce per tire. taking it to 8 ounces per tire that I am currently running.
Now unfortunately, I didn't think to test them at 7 ounces before i added the additional ounce, so I can't say for sure if the additional ounce was necessary or not. I do know however that the tires are balanced.
from my research on this subject, 7 ounces per tire is the reccomended number for 35s and to add an additional ounce for each inch in diameter above that. so 8 ounces for 36s, 9 ounces for 37s, etc. I don't think it will hurt to have more than the reccommended amount in each tire due to the way it works. however, having two few in there definitly wont work. so use this list as a guide and go from there.
Old 08-05-2006, 03:09 PM   #22
Dozer.
Here is a tire chart: http://www.innovativebalancing.com/BigTirechart.htm
And here is their link to order them: http://www.innovativebalancing.com/gallery1.htm
When looking up your size, also make sure that you know how many ply the tire is.
[SIZE="1"][COLOR="Blue"]Nicholas[/COLOR][/SIZE]
[COLOR="Blue"]Lock'd, Rock'd, but not ready to roll.
[/COLOR]
[SIZE="2"]There needs to be a Twelve Step program to stop the modding addiction![/SIZE]
[SIZE="4"][B][COLOR="DarkRed"][U]SAVE PARAGON![/U][/COLOR][/B][/SIZE] Visit [url]www.saveparagonap.com[/url] to get more information.
Dozer. is offline   Reply With Quote
Old 08-07-2006, 08:04 AM   #23
markc522
thanks for the info guys.
2003 wrangler x
Old 08-07-2006, 03:54 PM   #24
KrazyGimp
1982 CJ5
I am running 8 oz. in my 32's right now with no adverse effects. I am not sure what the down side would be of running too much, but I know mine work great.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline   Reply With Quote
Old 08-08-2006, 12:24 PM   #25
SHARPMACHINE
Man, this sounds great, I need to decide if I have the guts to try it on my new wheels and tires that I will be mounting this week??
33x12.5x15
try 7oz per tire?
SHARPMACHINE
1989 YJ RE 4" STD., 33X12.5X15 COOPERS ON BLACK CRAGER STEELIES, BESTOP BAKINI TOP. DRIVETRAIN = AMC 360 TF/727, NEXT = WINCH, TUBING AND AXLES????
other toys =
2002 YAMAHA KODIAC 4X4, 2001 400EX MODDED
2006 SKIDOO MXZX600SDI HO MODDED
1996 DODGE 4X4 12V CUMMINS MODDED
SHARPMACHINE is offline   Reply With Quote
Old 08-08-2006, 01:43 PM   #26
markc522
oh... one more question, will somewhere like discount tire (if you get the tires from them) put the beads in for you? will they still warranty the tires? i know thats not part of thier normal procedure.
i guess you could just buy the tires and have them mounted at a hole in the wall shop, and do the rotations yourself seeing that you would never have to balance them.
2003 wrangler x
Old 08-08-2006, 02:33 PM   #27
KrazyGimp
1982 CJ5
Not sure if you can find a shop to do it for you. I imagine there would be some sort of liability issues, since everyone is sue happy this day and age. I know the actual Dynabeads can be put in through the valve stem. As for the steel Daisy BB's, they are slightly too large and you will have to pop a bead off and just pour them in.
Old 08-08-2006, 02:38 PM   #28
KrazyGimp
1982 CJ5
Originally Posted by SHARPMACHINE
try 7oz per tire?
Try it. I have 8 oz. in my 32's and they work great. Like has been stated before, its worse to have too few than too many. I am not really sure what the downside of running too much is. If you have to little weight in there it will not balance them properly. I weighed mine out with an antique balance so im not even sure they are exactlly 8 oz. per tire, but it works fine.
Old 08-21-2006, 02:41 PM   #29
sbninja
What about noise, with the steel bb's?
BB's, seem the me the least expensive route, but what about corrosion?
2004 Jeep Wrangler Sport - Black
WARN steering box skid,Nth degree Oil pan skid
RE 3.5" - M.O.R.E. 1" BL - M.O.R.E. 1" MML
15x8 Tech1 Rock Crawlers (4.5" BS)
35"x12.50x15 Dunlop Radial Mud Rovers
Aussie locked 30/ Ultimate 35 kit w/detroit
Black Jeep Club v2.0 Member #49
See Jeep Here
And here
sbninja is offline   Reply With Quote
Old 08-21-2006, 09:47 PM   #30
Andrew F
I just put 8oz of air soft beads in my 32s and 9oz in my friend's 33s. It made a huge difference in both our Jeeps. I do still have a small vibe at 70mph, so the next time I rotate my tires I will put another ounce or two in my tires. Working at a tire shop makes this very easy.
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
[SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE]
Andrew F is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
