| Support JF - Equipment Drive and Future Downtime |
| Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
| #1 | |||
Registered User Join Date: Sep 2005 Location: Medina, OH Posts: 283 |
__________________ | ||
| #2 | |
Registered User Join Date: Mar 2006 Location: Oly, WA Posts: 1,465 | airsoft beads work well. I would not even bother unless I was running35s or bigger though. |
| #3 | ||
Registered User Join Date: Feb 2005 Location: Michigan Posts: 1,389 | Quote:
| #4 | ||
Registered User Join Date: Sep 2005 Location: Medina, OH Posts: 283 | Quote:
| #5 | |
Registered User Join Date: Jun 2005 Location: new jersey Posts: 1,779 | I'm running the dynabeads and I think they work great. __________________ 06 tj locked on 36's. |
| #6 | |
Registered User | I have them too, no complaints so far |
| #7 | |||
Registered User Join Date: Jun 2006 Location: Yakima, WA Posts: 1,140 | I put some Daisy steel bb's in my 32's, only because I mounted them myself and was tired of giving the tire store my money. They work great. None of my friends can believe it. It rides smooth as glass. __________________ 1982 CJ-5 Laredo 258, T-176, D-300 1972 240z in pieces... Quote:
| #8 | ||
Preamium Member | Quote:
__________________ lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00 44p '03p '6ı :5ɾɔ,37 s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47 The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad | |
| #9 | |
Registered User Join Date: Feb 2003 Location: Ocean Beach, San Diego, CA Posts: 2,392 | beads, no. BBs yes. I have 8 ounces of Copperhead BBs in each of my 35" tires. they work great! __________________ 92 Jeep Wrangler. YJ. High Output 4.0L Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods My RigRater Score: 682RRv1.0 with a BOA of 13.47 I'm now doing custom bumpers and lift installs in So-cal |
| #10 | |
Registered User Join Date: Apr 2004 Location: Glendale, AZ Posts: 558 | This has been a popular question lately on the boards. I run airsoft pellets and love them. __________________ 2005 Rubicon : 4.0 Automatic,4.11 gears,4:1 Transfer Case Teraflex 3" Coils,Rancho 9000x's,35" KM2's,(fenders...what fenders?), Cobra CB, Lowrance Baja 480c GPS,2"Wheel Spacers, Big Daddy Tie Rod,Superior Evolution Shafts. |
| #11 | |
Registered User Join Date: Jun 2006 Location: wilkes-barre Pa. Posts: 1,117 | beads in tires I tried plastic BB's maybe I didn't put enough in but it did not work, I used 4 oz's of Softair -12gr. 6mm plastic bb's, it seemed ok till the next day when i went on the expressway and it started bouncing bad, so I replaced the regular wheel weights, and I had to break the bead to put them in. My jeep as 31" factory rubber. |
| #12 | |
Registered User Join Date: Aug 2004 Location: Freetown, Ma Posts: 2,110 | I used 12oz of the dynabeads per tire in my 37" IROK's and they worked well __________________ Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
| #13 | ||
Registered User Join Date: Jul 2005 Location: Hershey Pa Posts: 1,891 | Quote:
Just what I was looking for , thanks ! I'm considering all the different options for balancing my new 36" TSL - SX's __________________ [SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation [/COLOR][/SIZE][/CENTER] [CENTER][B][/SIZE] [SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE] | |
| #14 | |
Registered User Join Date: Jan 2006 Location: DFW, TEXAS Posts: 678 | why wouldnt you use them on 33's or less? |
| #15 | ||
Registered User Join Date: Feb 2003 Location: Ocean Beach, San Diego, CA Posts: 2,392 | Quote:
but of course, the problem with rim weiughts offroad are plentifull: 1. when you air down, your tire can and will rotate itself on the rim as you wheel, thus displacing the weights and throwing the balance off 2. rim or stick weights will break or get torn off completel;y on the trail, thus throwing the balance off 3. though rare, i have seen it happen where somehow a weight gets tweaked and pushed in to the bead of the tire. it didn't puncture it, but it was a PITA to remove by using an internal balancing method like BB's or air soft or whatever you like, you eliminate all these problems and your tires are now self balancing. oh and for the guy asking if he used to few airsoft pellets, yeah you did. normal reccomendation i've seen is 7 ounces per tire for 35s, then add an ounce per inch over that __________________ 92 Jeep Wrangler. YJ. High Output 4.0L Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods My RigRater Score: 682RRv1.0 with a BOA of 13.47 I'm now doing custom bumpers and lift installs in So-cal | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Tires not balancing well--beads the fix? | imped4now | Tires & Wheels | 6 | 04-14-2009 08:02 PM |
| Question on balance beads | J-Mox | Tires & Wheels | 3 | 04-05-2009 04:48 PM |
| Balance Beads | blazer190 | Tires & Wheels | 2 | 07-07-2008 10:05 PM |
| Ceramic beads to balance tires...any experience? | myrockfight | Tires & Wheels | 32 | 09-20-2005 10:48 AM |
| Anyone balance with dyna beads? | IAJack | Tires & Wheels | 12 | 08-28-2005 08:01 PM |
Previous Thread
Next Thread
