07-27-2012, 05:37 AM
#16
I'd go Racelines...
I lucked out on a set of 5 used 15" Poison Spyderlocks with Nitto 35" Mud Grapplers. Let me tell you the Spyderlocks are heavy at around 32 lb and with a 35" tire my whole tire package is around 120 lbs which is heavy. The wheels & tires are not to bad to mount up except the spare tire which takes some effort!
07-27-2012, 04:59 PM
#17
Originally Posted by BSInc
but for repairibility and serviceablilty (because I drive by braile) I have to go with the Raceline's.
The Hutchinsons will be more reliable and easier to maintain as there virtually zero maintenance unlike normal beadlocks which require frequent re-torquing.No to mantion a whole lot easier to balance.As for the legal part if your beadlocks somehow fail while DD'ing it and kills someone your going to be SOL with the racelines as they do not conform to DOT standards.
07-27-2012, 05:31 PM
#18
D35 + Savvy Doors = TJOTM
Interesting points.... the fact that they are DOT approved when I first started doing research on beadlocks meant little to me really, but now that I've had time to really analyze the wheel designs I'm starting to understand more why this could be a big deal on a street driven vehicle. The fact that on a "traditional" beadlock wheel the actual seal on the outer bead is being accomplished in a manor that in no way represents the design characteristics of the tire is a little scary! Simply pinching the bead between two pieces of metal seems to work, but definitely doesn't correspond with the shape or intended design of a tire's bead area. I happen to work in the tire business, passenger car and light truck applications mainly, and regularly get reports on various tire failures and poor workmanship. Obviously Really BAD things can happen when tire's blow, or wheels fall off / fail. Hmmmmm......... How many of you really think that driving with a traditional beadlock wheel on the street is in some way negligent?
07-27-2012, 06:20 PM
#19
I spent 10 years working on vehicles that use the Hutchinson beadlocks(steel version) and they worked so well and rarely ever failed that all other vehicles were required to be switched to the same design double beadlocks.Talking about 8 wheel drive vehicles that weight 50,000+lbs and can tow over 60 tons.In 10 years I seen maybe 1-2 wheels fail.
07-27-2012, 11:52 PM
#20
Ok well I stand corrected on how I thought the outer beadlock ring was designed..... for a raceline wheel at least. It appears as if they do have the correct contour for the bead and not just a flat surface as I envisioned.
Still doesn't make them "dot" legal, but makes me feel a lot better about them.
07-31-2012, 11:12 PM
#21
Ok so I ordered the Raceline's yesterday. Can't wait to put my hands on them! FWIW, I found a vendor on Pirate able to sell a set for 1100 shipped! I was quoted from just about every forum vendor and this was the cheapest. Davesoffroadsupply.com was the vendor. Hoping they get here quickly.
08-03-2012, 09:24 AM
#22
Should have waited for a new beadlock design to come out designed and patented by B.A.D beadlocks. Check their facebook and youtube out.
08-03-2012, 11:02 AM
#23
I don't know... fastening those lock ring sections inside the tire with nuts and little clevis pins in real life as opposed to an animation strikes me about as easy as pulling teeth rectally.
Also, it looks like it will not allow DIY mounting of the tire.
08-05-2012, 09:32 PM
#24
You will NOT be disappointed. steel rings or the aluminium? I was impressed with the nice rolled lip on the steel ones. way better then a flat piece of metal you're just "coning in" when you tighten the bolts up. Get yourself a good torque wrench for 16-18 ft-lbs, you're gonna be close friends!
08-06-2012, 11:09 AM
#26
Fabramicator
Looks good! I have the same set only they are polished/polished, so far they have served me well
08-06-2012, 08:29 PM
#27
Thanks! I just spent some time ready your build thread. Very nice work man. A lot of things you've done I can see in my future.
08-08-2012, 04:13 PM
#28
King of Mac-istan
Originally Posted by brplatz
Plus Hutchinsons are DOT legal. Not sure on race lines
What is "DOT legal" exactly?
I hear it bandied about but have yet to actually find or see the DOT reg that spell out what is legal and what is not.
Do you mean "MFGR'd to DOT standard, methods or what"?
http://www.sema.org/federal-regulati...ermarket-parts
This is as close as I can find.
http://law.justia.com/cfr/title49/49...36.2.7.16.html
571.110
S4.4 Rims.
S4.4.1 Requirements. Each rim shall:
(a) Be constructed to the dimensions of a rim that is listed pursuant to the definition of test rim in paragraph S3. of §571.109 (Standard No. 109) for use with the tire size designation with which the vehicle is equipped.
(b) In the event of rapid loss of inflation pressure with the vehicle traveling in a straight line at a speed of 97 kilometers per hour, retain the deflated tire until the vehicle can be stopped with a controlled braking application.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
08-09-2012, 12:30 PM
#29
571.110
S4.4 Rims.
The DOT approval just means they have been tested by DOT or tests by other agencies and submitted to DOT.About the same process tires must go through before getting there DOT stamps.
08-09-2012, 03:48 PM
#30
King of Mac-istan
You didn't even read the links did you?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
