Beadlocks, Q's for those who know these things - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Beadlocks, Q's for those who know these things
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-31-2016, 04:20 PM   #1
Mousejockey
I have been told that airing down below 8 PSI is "Like night and day" and that a 'good' comparison is that going from 10 PSI down to 6-8 PSI is about the same improvement as going from 25 PSI to 10 PSI. True or False?
Does anyone have experience/opinions on Staun II beadlocks ? (coyoteents.com)
35-13.5/15 Toyo MT's on Daytona 15X10's 4" backspace
Mousejockey is offline   Reply With Quote Quick reply to this message
Unread 01-31-2016, 05:31 PM   #2
biffgnar
biffgnar's Avatar
First time I went below 5 lbs. it was eye opening.
I think if you search the reviews on Stauns are very mixed.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-31-2016, 06:29 PM   #3
jason m
Nothing but the facts
jason m's Avatar
Yes dropping below 5psi and even lower makes for great traction, I know I run around 2~3psi. But it also increases the stress on your drivetrain. Where before with a stiffer tire it can spin a little now with a mushy tire that conforms to a rock its up to the steering joints, axles, gears and so on up to move it or break parts.
So yes traction increases alot, but expect more breakage if your not built for it.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 02-02-2016, 12:23 AM   #4
christensent
2014 JK Wrangler
For me it depends what terrain I'm on. In deep snow, yes it is a night and day difference between 10PSI and 5PSI, and then another night and day difference between 5PSI and 1PSI.
For anything other than snow, I'm not usually going below 12PSI just because of the loss of ground clearance. I also find it to be diminishing return compared to snow where extremely low pressures are essential. I can get further down the trail at 12PSI just because of the clearance gain over 5PSI. Also I'd probably grenade my D44's wheeling in Moab at 2PSI.
Also realize it's very dependent on tires. A bias tire at 1PSI is going to look like a radial at 15PSI. Toyo MT's have really heavy side-walls so you'll want relatively low tire pressures compared to people on lighter sidewalls.
christensent is offline   Reply With Quote Quick reply to this message
Unread 02-02-2016, 08:44 PM   #5
Mousejockey
Im looking at the wheels and all I can think of is how many of those bolt heads Im going to sheer off on the rocks
Unread 02-02-2016, 10:03 PM   #6
jason m
jason m's Avatar
I'm going on seven ( hard ) years on bead locks and not one of the grade 5 bolts broken off. Lots of rock rash on them, I carry spares but never had a reason to put them on.
Lost a few inner beads, mostly on the rear steer trying to point the tires with most of the weight on the rear, but honestly no busted bolts.
Jason.
Unread 02-02-2016, 10:45 PM   #7
UTAH
I'll emphasize ground clearance as well. If there's a trade off to be made between traction and ground clearance - I'll choose clearance. Beating the underside of my vehicles has not gone well in the past.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline   Reply With Quote Quick reply to this message
Unread 02-03-2016, 08:29 AM   #8
biffgnar
biffgnar's Avatar
Experience similar to Jason. Never sheared a bolt head in the rocks. Yes, my rings are torn up and I have snapped a couple bolts with my socket wrench (install or breakdown is a little tedious), but never had a problem off road.
As far as clearance is concerned, I'm a big fan but until you see what real traction is you don't understand. Address the clearance other ways (e.g. tummy tucks, armor) and be thoughtful about where you are putting your tires.
Unread 02-03-2016, 12:29 PM   #9
KKiowaTJ
Hold a basketball full of air and see if you can palm it, how long and how many slips. Drop the pressure a few pounds and see instant results. Then take it down to minimal and it's night and day!
Same goes for holding a bar by fingertips, add rest of hand and no more problems. Good luck
MOPAR!
KKiowaTJ is offline   Reply With Quote Quick reply to this message
Unread 02-04-2016, 09:26 PM   #10
Mousejockey
Looking at the steel ones from Allied, rt51 or rt81
I like the look of the 81's better, but cant figure out why the price diff.....
Unread 02-04-2016, 09:42 PM   #11
Steve707
Steve707's Avatar
I don't mean to thread jack, but for those experienced with beadlocks, do you have any experience with DIY beadlocks? I'm thinking once I have on board air I might move to beadlocks.
Steve707 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2016, 06:10 PM   #12
jason m
jason m's Avatar
Mine are great lakes rings, work fine IMO.
Jason.
Unread 02-05-2016, 09:09 PM   #13
TSEJEEPERS
TSEJEEPERS's Avatar
I have been running these for a number of years.
http://totalmetalinnovations.com/in...e01goh77ij4uo5
Personally I believe the two biggest upgrades you can do to your Jeep are Lockers and Beadlocks.
Night and day difference. I never really noticed a difference in ground clearance. I run 6 psi no matter what a terrain.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
