Beadlock help. - JeepForum.com
post #1 of 6 Old 03-16-2014, 09:12 AM Thread Starter
Texsun
Beadlock help.
I just moved up to 37x14.00r15. IROKs from 35x12.50r15 Goodyear MTR "old style" with that said the 37s seem to have a larger bead than the old 35s and my lock rings won't smash down enough nor are my bolts long enough... Any suggestions? Get longer bolts?
Pictures since everyone likes them...
Texsun is offline
post #2 of 6 Old 03-16-2014, 09:34 AM
jason m
Nothing but the facts
jason m's Avatar
Start the rings with longer bolts, then see if you old hardware can reach the threads, if they can re-use them, if not get new hardware.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 6 Old 03-16-2014, 11:26 AM
Scrmngchicken
Jason.
^ That.
Scrmngchicken is offline
post #4 of 6 Old 03-16-2014, 10:32 PM Thread Starter
Texsun
Perfect, got new grade 8 hardware and it worked but took forever!!
Texsun is offline
post #5 of 6 Old 03-17-2014, 12:19 AM
92 Green YJ
92 Green YJ's Avatar
Grade 8 is overkill for beadlocks. Grade 5 is more than enough. No need to spend that much coin. Though it looks like your running like 16 bolt lock rings. So maybe grade 8 is needed. On my 32 bolt set up I was told I could use grade 2 even but I went with the 5 just to be safe.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #6 of 6 Old 03-17-2014, 08:11 PM Thread Starter
Texsun
I bought 70 grade 8 bolts with washers for $5.81 cheap enough for me. Everything I do is ridiculous or overkill!
Texsun is offline
