Backspacing Recommendation for Jeep - JeepForum.com
post #1 of 21 Old 03-20-2006, 01:27 PM Thread Starter
snakehunter
Getting ready to buy tires that will be for offroad use - Jeep is a DD but I'll put on some radials during the winter. I will still need to drive the Jeep to the trail and around town - it's my convertible.
2000 TJ w/ 4.5 RE lift
Buying steel wheels (15x8) and 33x12.50x15 GY MT/R's.
Stock D30 and D35
For trail use - mostly rocks and narrow trails between rocks and trees. Will less backspacing help with clearing rocks or other obstacles? Does it keep the body further away from the obstacle by having the tire out further? Or is it mostly for looks? How little can I get away with given my jeeps configuration.
I guess I looking for a recommendation between 4.5 and 3 5/16 and does it make a practical difference....
2000 Sahara RE 4.5, Alloy USA front Axles (D30) w/Aussie locker, Superior Super 35, 4.56 gears, OME Shocks, Centric Front Discs w/EBC Yellow pads, AtoZ Fab Rocker Guards,Goodyear MT/R 33x12.5x15 on 15x8 Rock Crawler 51's, other minor stuff...
/ | [____],
1---L-OlllllllO-
()_)()_)----)_) White Jeep Club Member #111
snakehunter is offline
post #2 of 21 Old 03-20-2006, 01:28 PM
MCanavan
You need at least 4.5" of BS to clear 12.5" wide tires. As far as I know the only positive to running more backspacing is a wider stance. The more you get the further out the tire sticks and more mud will end up on the side of your Jeep.
MCanavan is offline
post #3 of 21 Old 03-26-2006, 08:46 AM
jedeason
Stock D30 and D35
It is actually the total opposite. The more the higher the backspacing say 4.5 the tires will tuck more into your flares. The less backspacing the more your tires will stick out.
jedeason is offline
post #4 of 21 Old 03-26-2006, 10:13 AM
mctonyb
I'd go with a 4" backspacing. Doesn't stick out too far, less stress on the drivetrain, still have the "look", my $0.02.
TJ on tonnes at 110" WB with 40's and no money in my pocket
mctonyb is offline
post #5 of 21 Old 03-26-2006, 10:30 AM
M&C_TJ
M&C_TJ's Avatar
what about 3.75 back spacing i am putting 33x12.5 on 15x8 but i do want to keep the jeep narrow and safe with the amount of lift i am installing. like you said less stress is what i want for the 30/35 combo
Rock Krawler 5.5 X-Factor L.A. Rock Krawler Heavy Duty Steering System AA SYE and TW CV DS
D44 w/ superior shafts/D44 w/ usa alloy shafts from northridge ARB front and rear
Pro Comp series 97 Rims holding 35" BFG A/T
M&C_TJ is offline
post #6 of 21 Old 03-26-2006, 10:51 AM
mctonyb
3.75" is going to stick out a bit more. It's not a huge difference at all and will work. It is however a bit more stress, but nothing to write home about.
I would be more concerned with the Dana 35 axle out back with those tires then the backspacing on the wheels.
mctonyb is offline
post #7 of 21 Old 03-26-2006, 11:16 AM
M&C_TJ
M&C_TJ's Avatar
4" will clear everything just fine? and keeps them tucked in a hair more? yeah i hope to swap the 35 someday before i get too serious off roading.
so let me get it straight the higher the number the less it sticks out right? then would that be called more backsapcing?
M&C_TJ is offline
post #8 of 21 Old 03-26-2006, 11:43 AM
jedeason
Yes you are correct. The more backspacing the less the tires will stick out
jedeason is offline
post #9 of 21 Old 03-26-2006, 11:48 AM
M&C_TJ
M&C_TJ's Avatar
thanks...so i need less to get my 33x12.5 now i can know what i am talking about
M&C_TJ is offline
post #10 of 21 Old 03-26-2006, 11:57 AM
jedeason
[QUOTE=M&C_TJ]thanks...so i need less to get my 33x12.5 now i can know what i am talking about [/QUOTE
Check this out for steel wheels.
http://www.jegs.com/webapp/wcs/store...tegoryId=24471
You can get in 4.0 or 4.75. I am going to go with the 4.75s to fit 33x12.50x15 and will use a 1/4 inch spacer to make them fit. I am trying to keep my tires from sticking out as much as possible. You can get the same thing from Summit. Both Have free shipping. You may want to look at the ship weight since UPS has a limit of 150lbs. You may have to make seperate orders to keep from paying a surcharge.
jedeason is offline
post #11 of 21 Old 03-26-2006, 02:15 PM
M&C_TJ
M&C_TJ's Avatar
yelp those are the wheels i am going with but i am getting a killer deal with <www.4wheelparts.com> with RK97 and BFG but i wasnt sure on the backspacing. so with 33x12.5 on 15x8 will 4" work just fine or should i go with 3.75" to make sure?
M&C_TJ is offline
post #12 of 21 Old 03-26-2006, 03:08 PM
jedeason
Those will work just fine. It is recommended to have 4.5 or less of backspacing. They may stick out a little bit but you just have to get used to it or get wider flares.
jedeason is offline
post #13 of 21 Old 03-26-2006, 03:51 PM
BigPeters
go with 3.75"
"...same **** , bigger pile"
Gun Metal Blue Jeep Member #25
BigPeters is offline
post #14 of 21 Old 03-26-2006, 03:51 PM
M&C_TJ
M&C_TJ's Avatar
it wont bother me to have mud fling up my side i like the look i just want to keep my jeep as narrow as possible for trail. hell that is one thing i like about jeeps its and oversized 4wheeler right. so i would like to clear the tires just enough and keep them tucked in as much as possible too. any thoughts.
M&C_TJ is offline
post #15 of 21 Old 04-03-2006, 02:26 AM
Live4Him
Sorry to high jack! I am running 32x11.50 Wild cat RVTS on 15x8" rims my 2004 TJ x has a 2 1/2" Lift
Are these wheels the right setup for me. Soft 8 397 Series Wheel
Finish: Black
Size: 15'' x 8''
Bolt Circle: 5 x 4-1/2''
Rear Spacing: 4-3/4''
I too am trying to tuck my wheels in.
The darn rims I have now are 3.25 BS and they are slinging me with all kinds of nasty! Thanks for your help guys!!
Live4Him is offline
Need some help with wheel backspacing and lifted jeep Nickb1907 Tires & Wheels 16 06-13-2008 07:23 PM
2007 Jeep Hemi Octane Recommendation jpfisher Engines & Drivetrain 3 03-22-2007 02:03 PM
Different Jeep Backspacing Kiwi_TJ Tires & Wheels 10 08-31-2006 12:11 PM
JL SUB recommendation? Ethan03 Audio, CB & Ham Radios, GPS, & Electrical 7 10-04-2005 11:12 AM
Jeep Model Recommendation Dsess General Jeep & Off-Road Equipment 2 10-15-2002 12:02 AM
