Backspacing for 33x13.50 - JeepForum.com
post #1 of 1 Old 07-02-2013, 01:33 AM Thread Starter
archie05rubicon
Jeep Forum has been an invaluable resource in my research of how to lift my `05 TJ. I hope this precise question hasnít been asked.
I need help choosing the proper backspacing for Toyo Open Country MT 33x13.50 tires (approved rim width 8.5 Ė 11). I will run 7 inch flares so they should accommodate any of the choices I would make. But I am hoping to avoid restricting the steering stops.
My concern is overstressing the wheel bearings. The tires weigh 75 pounds and even the least backspacing I can get away with will be tasking the bearings beyond OEM specs.
I am installing the Old Man Emu 2.5 inch suspension lift and the JKS 1.25 biscuits. I have seen in threads here that this tire will fit on 8.0 inch wheels. (I like the 8 inch idea but will consider 10 inch wheels)
If I were going to run 12.5 tires Iíd simply go to the Cragar Soft 8 with 3.75 BS. Other ideas include; Raceline Rockcrusher Black 887 15x8 3.25Ē BS and 15x10 3.63 BS or Pro Comp Series 98 15X8 3.50Ē BS.
I wish there were 9 inch wheels but if there are I havenít found them. Thanks for reading this. What would you chose?
archie05rubicon is offline
