backspacing - JeepForum.com
post #1 of 7 Old 04-15-2013, 05:58 PM Thread Starter
atmuse18
backspacing
i have a 2005 lj rubicon unlimited which i am about to put a 4" lift on, and 33" tires
first, how much backspacing do i need to prevent rubbing
second, will 33" tires look bad with a 4" lift?
atmuse18 is offline
post #2 of 7 Old 04-15-2013, 06:07 PM
Jeffro06
Jeffro06's Avatar
4.5 to 4 inches....I'd go with 4 inches of backspacing if you're talking 33x12.5's.
33's and 4 inches of lift will look fine.
Jeffro06 is offline
post #3 of 7 Old 04-15-2013, 06:15 PM Thread Starter
atmuse18
http://www.4wheelparts.com/shoppingcart.aspx
will this tire/wheel combination work for me?
atmuse18 is offline
post #4 of 7 Old 04-15-2013, 06:45 PM
Jeffro06
Jeffro06's Avatar
The linky no worky.
Jeffro06 is offline
post #5 of 7 Old 04-15-2013, 07:24 PM Thread Starter
atmuse18
The linky no worky.
295/75R-16 tires or 33.3"
16x8 with -44 offset and 4.5 backspace
atmuse18 is offline
post #6 of 7 Old 04-15-2013, 08:46 PM
Jeffro06
Jeffro06's Avatar
295/75R-16 = 33x11.5's
You should be fine. I'd still like to leave a little margin for bigger tires, but the choice is yours.
Jeffro06 is offline
post #7 of 7 Old 04-21-2013, 10:40 AM
ArmyFO13F
I run 33s on a 4in lift. It's a pretty good look. My set up is 33x12.5 r15 duratracs on 15x10 pro comps with 3.75 backspacing. Before that I used stock wheels with a 1.25 spacer on same tires.
ArmyFO13F is offline
backspacing , lift , rims , tires
