Backspacing..'12 Wrangler wheels on 01 Grand Cherokee?? - JeepForum.com
post #1 of 6 Old 09-01-2012, 11:43 PM Thread Starter
BikerBri327
Hello. Will '12 Wrangler wheels will fit on an 01 Grand Cherokee? I think they are both 5 X 5 lug, just not sure about backspacing, etc? Any advice would be appreciated. Thanks
BikerBri327 is offline
post #2 of 6 Old 09-05-2012, 08:29 PM
ltrail
1984 XJ Cherokee
Pretty sure the GC is 5x4.5 and the wrangler that new is in fact 5x5, Google is your friend. Pretty sure they wont fit bolt pattern though.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 6 Old 09-06-2012, 06:40 AM
WXman
He already said both are 5x5 bolt pattern. And he's correct about that. His question is about backspacing, and I believe that the GC wheels were all 5.5" backspacing, whereas the JK wheels are 6.0" backspacing. So, they'll sit inboard another 0.5" which may or may not cause issues depending on what tires you run on them. On the outboard side they'll be even because the JK wheels are 0.5" wider, so the stance will stay the same. Only difference will be on the inside of the wheel and whether it'll contact any suspension parts on the GC.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #4 of 6 Old 09-06-2012, 02:20 PM
ltrail
1984 XJ Cherokee
I know what he said. But if he knew everything he wouldn't have asked. I Googled it and got mixed answers.
I'm a big boy and can admit I was wrong if they are 5x5.
ltrail is offline
post #5 of 6 Old 09-07-2012, 08:02 PM Thread Starter
BikerBri327
Backspacing Issues?
Hey All...Thanks for the Info. Does the .5 inch backspacing difference affect anything else like suspension or handling action or wear? The Wrangler tires are 255/75/17 and my GC uses 235/65/17 stock, So are these Wrangler wheels/tires going to fit on my Grand Cherokee with everything being stock? Many Thanks, Brian
post #6 of 6 Old 09-08-2012, 07:29 PM
WXman
255/75-17 is the largest tire ever put on any Jeep vehicle from the factory, as far as I am aware of. No way that's going to fit on an older Jeep, and especially not a Grand Cherokee, unless you have a lift kit.
With the larger offset of the wheels, what I think you should try and do is test fit them before buying. Tolerances are pretty tight inside the wheel wells on a Grand Cherokee. It would suck to buy them and then find out the inner sidewall is rubbing a ball joint or brake line or sway link.
WXman is offline
tj , wheels , wj
Will stock 17" 5 lug Grand Cherokee wheels and tires fit my 99 Cherokee Sport? JohnJeepSport Tires & Wheels 1 05-30-2012 08:08 PM
Grand Cherokee TSI 9017 Hollander Backspacing? terpsmandan Tires & Wheels 0 11-29-2011 08:43 AM
2004 Grand Cherokee wheels on 1999 Cherokee Sport? jbroese Tires & Wheels 2 07-30-2010 10:15 PM
2008 Wrangler wheels on 1999 Grand Cherokee pointech Tires & Wheels 0 05-30-2009 07:58 PM
Correct backspacing for Wrangler Wheels HobieSun Tires & Wheels 3 07-16-2008 10:20 AM
