Backspacing - JeepForum.com
post #1 of 5 Old 08-06-2010, 07:34 PM Thread Starter
vanhorn1290
Backspacing
Hello everyone! I just upgraded to a 4" suspension lift. I currently run 31*10.50*15's on stock aluminum wheels. Before i got my lift they rubbed in extreme turning situations.
I want to run 33*12.50*15's. I live in PA and do light wheeling. What is the minimum backspacing I can have and not rub or stick out too far? I don't want to have to get fender flares but I can't risk being pulled over either.
From what I've found 4" spacing will stick my tires out. Will 4.5" spacing work with minimal rubbing or should I go 4.25 just to be safe. Thanks for your help and input.
vanhorn1290 is offline
post #2 of 5 Old 08-07-2010, 01:48 AM
Jeepster83
since you have to conform to certain regulations and youre trying to balance that with what you want i would say try 4.5". dont go out and buy them just to try them out. maybe you know someone who has the setup or something similar to the setup youre looking for and you can temporarily swap tires/wheels with them to get a better idea of what you need.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #3 of 5 Old 08-07-2010, 05:21 AM
mknight759
Well i have been looking around to and I can't seem to find any 15in wheels with anything more than 4in backspace gotta go to a 16 or 17 in rim. look and and make sure that it will not be htting any steering components also.
mknight759 is offline
post #4 of 5 Old 08-07-2010, 07:07 AM Thread Starter
vanhorn1290
Thank you both very much. Another question.
Can I run 33*10.50's instead of 12.50's on my stock TJ wheels? Or will the backspacing still be an issue. That way I could still have my 33" tires without having to buy a set of wheels too.
post #5 of 5 Old 08-07-2010, 12:30 PM
Jeepster83
i have 33x10.50's on my stock Canyons which are 15"x8". i had some slight rubbing against the lower control arms but it was easily remedied with about 2 or 3 washers behind the steering stops.
Backspacing for 31/10.5/15? MotorGear327 Tires & Wheels 18 02-27-2008 08:10 PM
backspacing spikeystrip Tires & Wheels 2 02-09-2008 08:04 AM
Backspacing Vauxilicon05 Tires & Wheels 0 07-02-2005 01:28 PM
Is this backspacing right? GIJOE Tires & Wheels 0 06-30-2005 05:00 PM
Backspacing ???? mud n rox Tires & Wheels 1 05-01-2005 09:15 PM
