Anyone had this happen to their tire? - JeepForum.com
post #1 of 6 Old 07-06-2013, 08:38 PM Thread Starter
bmensing
This is my front left tire. It's wearing unevenly that I have recently noticed. All other tires are fine. Anyone able to help me diagnose?
bmensing is offline
post #2 of 6 Old 07-06-2013, 08:51 PM
tkenny11
You might need to rotate them? My tires do this too and start to get obnoxiously loud, but once I rotate them it gets a little better. I think when you put the front tires on the back it rounds them out more.
tkenny11 is offline
post #3 of 6 Old 07-06-2013, 08:53 PM
FunkyJeepz
Yea proper psi and frequent rotation will get even wear and longer life. I just got mine done today. Every 3k to 4k they're rotated.
FunkyJeepz is offline
post #4 of 6 Old 07-06-2013, 11:53 PM
ChadH
I can't really tell from the picture but it appears you have excessive toe on the tires. So instead of the tires rolling "straight" down the road, they are constantly angled either in or out which is causing a sideway scuffing action, thus uneven wear. If it is in the front, it's easy to fix. If it is the back then you need to have a friend drive behind you and make sure you are not dogtracking before you get too deep into it.
Life is Good
My Build:
http://www.jeepforum.com/forum/f22/majestic-eagle-1434780/
ChadH is offline
post #5 of 6 Old 07-07-2013, 02:30 PM Thread Starter
bmensing
I rotate regularly and it's only happening to the one tire and its never happened to any of the front right tires before so I am going to have them check the tow on that side. Thanks for the input everyone. It's pretty frustrating and I was hoping it wasn't anything suspension related that was a big issue or going to cause future problems.
bmensing is offline
post #6 of 6 Old 07-07-2013, 07:08 PM
GilaMtnJeep
GilaMtnJeep's Avatar
If it's on the front and only one tire, check for worn components and leaking shock on the suspect side.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
