Another - Will they fit a TJ w/o a lift? - JeepForum.com
post #1 of 9 Old 06-18-2013, 08:32 PM Thread Starter
scottv720
I just bought my 1st jeep, a completely stock 1997 Wrangler TJ SE. I need to mod it incrementally or my wife will kill me
I got a good deal on some used Mickey Thompson Baja ATZ 32x11.5x15 on Mickey Thomson Classic II 15x10 wheels. The owner wanted to get even bigger tires/wheels.
The wheels have the following specs:
lug pattern: 5x4.5
Offset: -48 millimeters
Backspace 3.625 inches
With this offset and backspace, do you think a 32x11.5x15 tire will rub w/o a lift? If so, what would be the minimum lift size 2,3,4"?
I plan on eventually getting a lift but, I would like to use these tires in the mean time.
Thanks in advance. This feedback should save me many hours of trying this out.
Scott
scottv720 is offline
post #2 of 9 Old 06-19-2013, 06:45 AM
biffgnar
biffgnar's Avatar
Yes, you probably will rub. Put on a 2" coil spacer lift for now with some new shocks and set your bumpstops correctly and you should be OK.
Romney in 2020!
biffgnar is online now
post #3 of 9 Old 06-19-2013, 10:15 AM
speedyrev
Stick with 31's on stock height
speedyrev is offline
post #4 of 9 Old 06-19-2013, 10:41 AM Thread Starter
scottv720
Thanks biffgnar. I will go ahead with the lift and shocks. What are the bumpstops?
Scott
post #5 of 9 Old 06-20-2013, 02:14 PM
lilyellowTJ
Scott. Bumpstops are inside your coils. It adjust your down travel when your flexing and prevents your tires from rubbing.
lilyellowTJ is offline
post #6 of 9 Old 06-23-2013, 02:09 AM
Charley3
Note: bumpstop spacers are one thing, coil spacers are another. This post is about bumpstops and related topics, including bumpstop spacers.
Bump stops are the bubber bumpers inside you coil springs. The bumpstops are mounted to frame or axle housing, I forgot which. I think bumpstops are mounted to axle housing for front of Jeep, and frame for rear of Jeep.
Stock Jeeps already have stock bumpstops.
When guy(s) tell you to get bumpstops or add bumpstops, what they really mean is longer bumpstops aka extended bumpstops.
Longer bumpstops are acheived by one of a few possible methods: You can install longer bumpstops (made of polyurothane), or you can install bumpstop spacers between you stock rubber bumpstops and their mounting point, or you can install a spacer in the place where stock rubber bump stop lands.
Usually spacers are made of aluminum, but the best spacers are made of rubber. I prefer rubber spacers because they add some extra cushion in addition to spacing.
Metalcloak makes good rubber bumpstop spacers for front axle. Not sure if they make them for rear.
Here is what I recommend to extend front bumpstops AND add some cushion for a softer landing when suspension bottoms on big bumps AND won't get caught in coil (won't scrape side of coil).
Buy Metalcloak rubber bumpstop spacers that mount to front axle housing where the stock rubber bump stops land (front bump stops are mounted at top of coil spring). The Metalcloak rubber bumpstop spacers come in 1", 2", 3", and so on. Get as much spacer as is appropriate.
For rear coils, buy a spacer that mounts to frame between frame and stock rubber bump stop. I think aluminum spacers are the only option. Not sure what brand. Probably any brand is fine (or make your own).
Note that I'm suggesting using stock rubber bumpstops with spacers (NOT buying longer poly bumpstops). Why? Because rubber is softer. Rubber bumpstops are cushier than poly bumpstops. So it's a softer experience when suspension bottoms on a big bump. In the front you get even more cushion from the Metalcloak rubber spacers.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #7 of 9 Old 06-23-2013, 02:15 AM
tjtrucker
Yes I think rubbing will occur if you don't install a lift of some sort. I did a Skyjacker 2.25" Budget boost lift kit, it comes with Skyjacker Hydro shocks that are long enough for a 3" lift kit. So in the future, if you decide to ditch the spacers and and replace the the stock springs with 2.5" or 3" springs, you won't have to change the shocks. I also replaced the front spring Isolators with .75" ones, that gave me a little more lift up front. here is the link for the lift kit that I bought- ($219) http://www.4wheelcustoms.com/Product....asp?ID=193233 The backspacing will be about perfect, but you don't have to go with 15x10" wheel, I went with a 15x8" wheel with the same backspacing, and it fits great.
tjtrucker is offline
post #8 of 9 Old 06-23-2013, 02:29 AM
Charley3
This post is about coil spacers (lift).
I think 3/4" poly coil spacer would be enough lift for 32s, but if you want to use 1" or 2" poly coil spacer, that's OK too
However, with 3/4" or 1" spacer you don't need to buy longer shocks. Just keep using shocks you have.
Charley3 is offline
post #9 of 9 Old 07-05-2013, 05:38 PM
tjtrucker
A "budget boost lift"- (BBL) is the same thing as a coil spacer lift. If the OP wasn't going to take it off road, or drive over speed bumps, maybe they could get by with a one inch with 32s (but I doubt it). the 3/4" spacer is only slightly thicker than the stock rubber spring isolator.
"Mud Happens"
Member)
15x10 , backspace , offset , tj
