another tire width thread - JeepForum.com
post #1 of 11 Old 09-30-2013, 11:21 AM Thread Starter
kid4x4
I have been reading for days on the 10.5 width tires at 31" of height. I cant find anything about having a 11.5" width with spacers. If i add a 1.25" wheel spacer or larger will i be able to fit the 11.5" width with out major rubbing or any rubbing at all. i don't off road i just like the aggressive look. this jeep will just be an on road vehicle.
This is on a stock TJ
Thanks
kid4x4 is offline
post #2 of 11 Old 09-30-2013, 11:43 AM
biffgnar
biffgnar's Avatar
You should be fine with 11.5s if you put on spacers.
biffgnar is offline
post #3 of 11 Old 09-30-2013, 12:23 PM Thread Starter
kid4x4
do you think the 1.25" spacer is enough or should i go to a 1.5"
kid4x4 is offline
post #4 of 11 Old 09-30-2013, 12:34 PM
WXman
I'd do 1.25. Remember, only 1/2 of the extra width of the tire will be on the inside.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #5 of 11 Old 09-30-2013, 01:00 PM Thread Starter
kid4x4
do you think there will be an rubbing on the fender flares?
1999 Wrangler TJ 4.0 I6
1999 C5 Corvette
2001 F-150 3" lift
1988 Speed Boat
kid4x4 is offline
post #6 of 11 Old 09-30-2013, 01:23 PM
biffgnar
biffgnar's Avatar
Probably not if you aren't going offroad.
biffgnar is offline
post #7 of 11 Old 10-05-2013, 11:30 AM
Spud100
I have 1.5 spacers with 31s. Gives me huge space around the tires. You should have no problems either way.
Spud100 is offline
post #8 of 11 Old 10-22-2013, 12:43 PM Thread Starter
kid4x4
what if i decided to run 32x11.5r15 with stock wheels. would i need a 1.5 inch spacer or would a 1.25 work? Going up that extra inch on the tire, would it cause any issues. remember this is just for the road. I know I could put on a BB but im trying to see what i can get with stock.
1999 C5 Corvette
2001 F-150 3" lift
1988 Speed Boat
kid4x4 is offline
post #9 of 11 Old 10-22-2013, 12:54 PM
biffgnar
biffgnar's Avatar
Spacers help with rubbing on control arms and swaybar links when turning. They don't help with rubbing on fenders from having tires with too large a diameter. Stick to 31s with no lift.
biffgnar is offline
post #10 of 11 Old 10-22-2013, 07:43 PM Thread Starter
kid4x4
ok I just changed what im doing. I ordered a 2" bb, im thinking of doing 33x10.5 tires. Will this work on my stock rims? If I want to go with 12.5" width would i need new rims? with like 4 bs?
1999 C5 Corvette
2001 F-150 3" lift
1988 Speed Boat
kid4x4 is offline
post #11 of 11 Old 10-23-2013, 08:40 AM
biffgnar
biffgnar's Avatar
With 33s and BB you'll probably want a small BL also.
For 12.5" tires, you'll want to be net 3.75-4.25" BS area. Either by buying new wheels or using spacers.
biffgnar is offline
