All Terrain Tires - Page 10 - JeepForum.com
 1Likes
post #136 of 411 Old 02-25-2008, 08:47 AM
NCJEEPFAN
2006 WK
Originally Posted by cjbert View Post
Anybody have experience with Dayton Timberlines? 83 CJ7 mostly road use but some trail driving too.
sorry, this is probably a little too late. i have a set of Dayton
timberlines on my TJ. i love them. they ride smooth, the wear has been great, quite (for a AT) and they were pretty cheap. i believe i paid approx $87 or so per tire and thats for a 31x10.50.
i will probably go witht hem again but in a 32 next time.
06 WK Laredo
3.7, 4wd......lift and tires coming soon!
NCJEEPFAN is offline
post #137 of 411 Old 02-25-2008, 09:18 AM
ajmorell
ajmorell's Avatar
Originally Posted by redsoxski View Post
Anbody have any mileage or long term report on the **** Cepek FCII's yet?
What kind of information are you looking for? The FCIIS are rated for 60,000 miles.
ajmorell is offline
post #138 of 411 Old 02-25-2008, 03:42 PM
redsoxski
redsoxski's Avatar
Just looking for what the real world mileage and experiences are. I don't trust manufacturers ratings..
redsoxski is offline
post #139 of 411 Old 04-07-2008, 08:58 PM
ram130
I have a 05 TJ with 2.25" coil spacers. I am in the market for new tires and am looking for some suggestions. I would like to get a good A/T tire to be used mainly on road and in the sand. Ideally, I won't be buying new tires. I will just use the stock TJ rims that come with the 30" tire package on the Sport. I think this limits me to a 10.5" wide tire and everything I've seen about the amount of lift I have puts me at a max dia of 32.
Does anyone know of a 32 x 10.5 tire? I know the PF Dirt Grip is a large 31 so I am considering it as it is supposed to be very good in the sand but I'm worried about on road noise and tread wear. Anyone have an experience with this? Also, if I am not doing any hard off roading (mainly just beach driving) can I squeeze a 33 x 10.5 A/T in there? I don't know that I will ever have my springs compressed to the bump stops so I wonder if I can get away with them...
Any thoughts/suggestions would be appreciated. Thanks.
ram130 is offline
post #140 of 411 Old 04-08-2008, 08:27 AM
Fargo
I don't have any info on the Parnelli Jones Dirt Grip, but from what I have seen in the specs they are as close to a 32x10.5x15 you will find.
I think if you spend an extra $100 you could put a 1" body lift under your Jeep and put the 33x10.5 tires on it. I believe there are numerous people running this setup. Check around the forum a little and you should find some pictures.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #141 of 411 Old 06-02-2008, 02:44 PM
jpwagoneer1979
1979 FSJ Wagoneer
Anyone had experience with goodyear wrangler GSA's?
jpwagoneer1979 is offline
post #142 of 411 Old 06-02-2008, 03:34 PM
Fargo
You are joking right? Please tell me your joking.
Since I see this is only your 2nd post and you are new to the forum I will assume you are actually serious. The Wrangler GSA came stock on the TJ for many years. They are fine on dry pavement but they suck pretty much everywhere else. I don't think anybody here likes them. They have poor traction and very week sidewalls. Most people here would only use them if they got them for free. Even then I don't think they would use them. I think if you do a search on the forum you will find out a lot of info on them.
By the way... Welcome to the forum. This is really a great forum to get info about Jeeps.
6spd manual
Fargo is offline
post #143 of 411 Old 06-02-2008, 07:14 PM
bman9089
bman9089's Avatar
Oh, wow......just......wow.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #144 of 411 Old 06-03-2008, 07:59 AM
Fargo
jpwagoneer1979 - Don't take the Wrangler comments personally. This really is a friendly forum. People just really don't like those tires and they get discussed here a lot. Stick around and you'll learn all kinds of good info.
6spd manual
Fargo is offline
post #145 of 411 Old 06-04-2008, 12:19 AM
bman9089
bman9089's Avatar
meh, don't mind me, I'm just bieng a smart ***.
yes, the wrangler GSAs suck in nearly everything. The only good time I had with them was taking them out on a trail to beat them down to a pulp before I mounted my current STTs.
bman9089 is offline
post #146 of 411 Old 06-16-2008, 06:32 AM
winkosmosis
Originally Posted by pappa-g View Post
I just got back from the tire shop today with a new set of 32" BFG A/Ts on the Jeep. They replaced a set of 31" BFG A/Ts with 50k miles on them. Shop around prices for the set went from $820 down to $610 with all the b.s..
The 31" tires I ran at 28 psi. The new ones were at 47psi?!?!?!?!
I dropped them down to @ 26 and called the shop, they "put them at the reccomended psi on the side of the tire" (read this as the maximum allowable pressure). Now am I ate up like a soup sandwich or are these bozos in left field? Doesn't it go like bigger tire = bigger surface area. Bigger surface area = less weight per sq in. Less weight per sq in = less air pressure needed.
Now I have never claimed to be any type of rocket surgeon but you don't get 50k out of a set of tires by running them at max air pressure.
Any Thoughts?
OK I found my happy pill PEZ dispenser, I'll be alright.
It's beside the point what the optimal pressure is. You don't ever inflate tires to the max pressure on the sidewall, because that number has nothing to do with anything except what it says-- It's the max pressure the tire can take. The pressure you use depends on the vehicle. I'd never ever go to that shop again because apparently they hire monkeys. Honestly, how can someone who WORKS AT A TIRE SHOP not know that the max pressure is not the same as recommended?
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #147 of 411 Old 07-03-2008, 02:18 AM
Jeepguy1977
Jeepguy1977's Avatar
They aren't even good on dry pavement. Wear funny, look worn out long before they are, and handle strangely.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #148 of 411 Old 07-06-2008, 08:19 PM
Smitty123
hi i have a 1999 jeep cherokee sport, right now it has a stock suspension but will soon have a 3.5inch lift kit...with the lift it is suppose ot be able to have 31X10.50 inch tires on it. i am wondering what the best comination would be for mickey tompson 31x10.50 inch tirees with 15 X?????? rims...im wondering how wide of rim to get?
Smitty123 is offline
post #149 of 411 Old 07-06-2008, 08:36 PM
Smitty123
do you know what 31.10.50 inch tires and 15x?? rims would go good togeather?
post #150 of 411 Old 07-06-2008, 08:46 PM
Smitty123
do you knwo if mickey t 31x10.50 will fit 15x8 or 15x8.5 rims?
a/t , all terrain , all-terrain , popular , tires , variations
All-Terrain vs Snow Tires mofo13 Tires & Wheels 4 10-31-2008 02:12 PM
Mud Terrain Tires - Siped or Not 87Feep Tires & Wheels 15 11-15-2006 02:07 PM
mud terrain tires gmbtj Tires & Wheels 9 12-14-2004 06:00 PM
X-Terrain tires jeeprs-creeprs Tires & Wheels 17 01-04-2003 09:26 PM
Tires - all terrain? 93 Blue Demon YJ Tires & Wheels 3 12-12-2002 10:57 AM
