Align / Balance Question - JeepForum.com
post #1 of 9 Old 05-27-2009, 11:26 AM Thread Starter
DominicR
2011 JK Wrangler
Sorry for the basic question, but do your tires need to be attached to your vehicle for them to be balanced / aligned? In other words, if you buy tire / wheel sets, do they come balanced / aligned so that you can just replace the current tires, or when you get them do you have to take them somewhere to get it done. Thanks!
DominicR is offline
post #2 of 9 Old 05-27-2009, 01:18 PM
VTJeePTJ
They balance the tire/wheel off the vehicle on a seperate machine so the answer to that is no. The tires do need to be on the vehicle for an alignment though as they factor into all alignment measurements.
2003 Jeep TJ- 4" Nth LA, 4.88/ARBs, Rubicrawler, 33's, Savvy Steering, Poison Spyder Armor, etc.
VTJeePTJ is offline
post #3 of 9 Old 05-27-2009, 02:08 PM Thread Starter
DominicR
2011 JK Wrangler
Thanks for the reply. A follow up question: if I get a set of wheels / tires - I should have them installed professionally so they can be properly aligned as opposed to just taking of the existing tires and replacing them myself?
DominicR is offline
post #4 of 9 Old 05-27-2009, 07:27 PM
Wild Hare
if you are not having any issues with your current alignment as in wearing your existing tires uneven etc, then there is no reason for an alignment. so you could buy new/different tires and wheels and have them balanced then take off your old ones and put the new ones on yourself.
Wild Hare is offline
post #5 of 9 Old 05-27-2009, 08:16 PM
flatlander757
Click the link in my sig about TJ alignments. It's a good read and everything will apply to your JK aside from maybe the factory specs and some other small bits. The concepts and definitions are the same though
You are confusing mounting and balancing with aligning your vehicle.
You aren't aligning the wheels and tires themselves... you're aligning the suspension. You don't get your "wheels and tires aligned."
The rim is either straight or it's bent slightly. Nothing to do with alignment.
When you get your Jeep aligned the tech will spin the alignment "heads"(things that attach to each wheel for the computer to read off of), and it will compensate for any wheel runout it may have up to 1.00 degrees generally.
I wouldn't bother trying to mount the tires yourself. I have the ability to do so myself with just a few wrecking bars, but the fact is it's a total pain to do so. The $100 or whatever it may cost to have them all mounted and balanced is well worth it.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #6 of 9 Old 05-27-2009, 08:18 PM
Wild Hare
flat lander, i doubt he was thinking of mounting the tires on the wheels himself. i think he meant bolt the tires and wheels on his rig after buying a tire/wheel combo. if the guy can't bolt on his own tires and wheels he might as well sell his jeep and buy a mini van.
post #7 of 9 Old 05-28-2009, 08:44 AM
JazzDelay
Getting your tires balanced really helps, but it's not fun to try and do... If you have large tires you have to make sure the place you want to go to has big enough machines to do it. We tired doing my friend's tires on my machines at school and it was a hassle..
JazzDelay is offline
post #8 of 9 Old 05-28-2009, 01:48 PM
Amadeus3
1997 XJ Cherokee
I would also suggest throwing in some airsoft pellets in addition to the conventional rim balancing. The rim balancing tends to have a hard time balancing larger diameter tires if they aren't pretty uniform.
6.5" Rough Country lift, locked on 35x12.5x15" BFG KM's, Nate's 4x4 Slimline, Smittybilt XRC10, skids, random junkyard upgrades
Amadeus3 is offline
post #9 of 9 Old 05-28-2009, 05:21 PM
flatlander757
Ahh, reading his post again I reckon you're correct.
In that case yes just bolt them on and torque to spec.
Currently Jeepless.
Balance question imjbinkc Tires & Wheels 2 06-28-2009 09:07 AM
Question on balance beads J-Mox Tires & Wheels 3 04-05-2009 03:48 PM
to balance or not to balance xjgnar Tires & Wheels 5 10-08-2008 04:20 PM
Tire Balance Question Bill87GT Tires & Wheels 2 09-16-2007 08:26 AM
pellets to balance tires question chrisvr6 Tires & Wheels 1 08-31-2006 09:02 PM
